Flowmaster And Cold Air Intake
Can I expect a 2 mpg increase by adding a flormaster system and then a K+N filter or perhaps a cold air intake kit?
2004 4x4 extended cab shortbed
5.3 with automatic
expect a slight decrease in economy with flowmaster, for an intake it will make up for the Flowmaster and help a bit.
Neither are worth the money if all you're looking for is mileage.
I observed the following on my 2006:
stock - 18-19 MPG highway
added AEM brute force intake - no change in mileage
then added Corsa cat-back - 0.5-1 MPG increase
Can't say it was all the Corsa or a combination of the exhaust and intake as I already had the intake on when I added the Corsa.
For me I love the sound and look which is why I did it. Seems to pull a little better, but without a dyno can't quote benefits.
On my 07NBS 5.3 Sierra, the K&N replacement filter actually caused a 2mpg DECREASE in mpg. Upon further examination, I have come to the conclusion that the air box design on the Sierra is such that the K&N fits in "up-side-down". As the K&Ns ARE directional with respect to flow, I am assuming that, since it had to be installed "up-side-down" that it actually caused a performance decrement.
SO, to answer your question, no, the K&N will hurt to the tune of about 1-2mpg, based on my direct experience. I pulled it out after 1 tank of gas --- it was THAT noticable on performance DECREMENT and mpg.
Now, my experience on Flowmasters has been mixed. On a F__d F150 (5.4l) I owned in a previous life, it gave me a 1-2 mpg increase. On an F250SD (5.4l) the Flowmaster gave me no noticable improvement in gas mileage, though it didn't DECREASE it either.
Compared with "brand F" mufflers, it appears the NBS factory mufflers run pretty open, i.e. not as restrictive as the F__ds.
I have no specific experience with Flowmasters on GMs wrt gas mileage. My guess would be that, with the combination of a FM and K&N filter cartridge, you will, either, break even, or actually go down a bit in mpg, with the K&N being the bigger culprit.
Now, I have a GMPP CAI that gave me approximately a 1mpg increase. I would recommend a CAI rather than just the K&N filter. Some like GMPP, others prefer Volante, and still others like the K&N CAIs. Either way, a whole CAI system, I would guess, will help you out on the mpg side over the filter.
CAI's are no help to fuel economy, big myth. More Air=More Fuel Added by computer to correct mixture, giving you either equal or less mpg. You get somewhat better performance, a better looking tube, and a louder engine.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
