Stabilitrak Off
Can I turn off the StabiliTrak system?
I just bought an '08 GMC Sierra 1500 with locking diff. The owners manual says I can turn off the StabiliTrak system but doesn't say how. I don't have any buttons under the A/C controls, just an empty slot about the size of a deck of cards.
stabilitrak is a Crew Cab option
your locking diff is completely different ..
Stabilitrak is std on Crewcab, but it is available as an option on ext cabs as well.
I have it on my 07 extended cab and if turn it off with the switches below the heat controls it says thats if off but if i play in the snow it still comes on if i'm spinning the tires....weird. Also while driving down the highway last week the stability control service soon came on, then i resarted and it went off.
Was there not a post on here about somebody wanting to "brake torque" the rear wheels? Wanted to turn 2 things off, stabili-trac and something else.
Anyone else remember this or have thoughts?
if he doesnt have the buttons stating ' stabilitrac' then i guess he didnt option it
wouldnt the window sticker state if option is purchased ??
could always ask the the VIN build sheet - that would tell you everything about your new baby..
I have it on my ext cab also. It sounds like you have traction control turned off and not the Stabilitrac. Do you press and hold the button for 5 seconds? If not, only the TC is turned off. When I turn mine off I can spin and slide all I want.
So if you just tap the button then stability control goes off and if you hold the button for 5 sec the traction control goes off?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
