I Have A Problem With My Injector Connector
soybetio
Hey, hello everybody!
This is my first thread on this forum!
Well I need assistance from the experts, I have a 1999 Chevy Tahoe with a 5.7 Vortec engine.
I just got the "check engine" light on, so I went to the mechanic to see what's the problem...he told me that the little injector connector was bad, he took a little screwdriver and push the cables down...with this, the check engine light went off and the problem was gone...but after a couple of miles the check engine went on again :lol:
I bought a new connector injector and I replaced the old one, but the problem remains!
Could you please give me a hand with this? I don't know...it seem's like I have a misfire in one of the injectors but replacing the injector would solve the problem? my Tahoe is running like a 4 cilinder car :D
This is the engine :)
This is the part that i'm talking about...
And this is my Tahoe!
Did you check the connector that is wired to the computer harness. Or check the connector that is hooked up the the PCM and the wires that run from the PCM to the injectors to be sure.
I just got the "check engine" light on, so I went to the mechanic to see what's the problem...he told me that the little injector connector was bad, he took a little screwdriver and push the cables down...with this, the check engine light went off and the problem was gone...but after a couple of miles the check engine went on again :crackup:
Could you please give me a hand with this? I don't know...it seem's like I have a misfire in one of the injectors but replacing the injector would solve the problem? my Tahoe is running like a 4 cilinder car :crackup:
This is the engine :D
So you replaced the hole injector connector! Wow that is alot of wire crimps. I hope you did a good job cuz it's possible you created more problems doing that. Put to you this way for the 12 years doing this I have never replaced a injector connector on a 5.7, but I have replaced tons of injector units. I'll post the schematic on the injector connector so you can double check it and also post a bull the I think MAY help you. :crackup:
999999995.gifSubject:Special Policy Adjustment-Sequential Central Port Fuel Injection (SCPI) Failures in California Only (YF5 Emission Equipped) #99066G - (11/05/2003)
Models:Certain 1996, 1997, 1998, 1999, 2000, 2001, 2002 S/T, M/L, C/K, G, P, W4/NPR Trucks and 2003 NPR Trucks
Equipped with 4.3L (RPO L35-VIN Code W or RPO LF6-VIN Code X), 5.0L (RPO L30-VIN Code M) or 5.7L (RPO L31-VIN Code R) Engine and California Emission Equipped (RPO YF5)
This bulletin is being revised to emphasize to Dealers the important of replacing the engine SCPI fuel assembly with the new MFI fuel assembly if the vehicle has already received an injector cleaning. Please discard Special Policy Bulletin Number 99066F, dated March, 2003.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss1-1400638">
Condition
Some owners of 1996, 1997, 1998, 1999, 2000, 2001 and 2002 model year S/T, M/L, C/K, G, P and W4/NPR trucks and 2003 NPR trucks that are registered in California, equipped with 4.3L (RPO L35 and VIN Code W or RPO LF6 and VIN Code X), 5.0L (RPO L30 and VIN Code M) or 5.7L (RPO L31 and VIN Code R) engine, and California emissions (RPO YF5), may experience a Service Engine Soon light, misfire, rough idle or hard start due to a deposit build up on the Sequential Central Port Injector (SCPI) poppet valve(s). The deposit build up may cause injector poppets to stick closed. Fuels used in California have been found to interact with the SCPI system to cause the deposits.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss2-1400638">
This special policy covers the SCPI failure condition described above for a period of ten (10) years or 200,000 miles, whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
The repairs will be made at no charge to the owner. This special policy applies ONLY to repairs requiring SCPI system servicing and/or injector cleaning and/or MFI assembly replacement of the SCPI system. The customer should not be charged for performing a system check when it is determined that the SCPI system is not the cause of a customer complaint (labor operation T5532 is provided to submit claims for such system checks). Any additional necessary diagnosis and repairs that are not related to the SCPI condition are NOT covered by this special policy. The customer should be informed that any further service that is not covered by new vehicle warranty will not be covered by this policy.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss3-1400638">
Vehicles Involved
Involved are certain 1996, 1997, 1998, 1999, 2000, 2001, 2002 S/T, M/L, C/K, G, P, W4/NPR and 2003 NPR model vehicles registered in California, equipped with 4.3L engine (RPO L35-VIN Code W or RPO LF6-VIN Code X), 5.0L engine (RPO L30-VIN Code M) or 5.7L engine (RPO L31-VIN Code R) and California emissions (RPO YF5). This Special Policy covers all vehicles within these model years, with these engine and emission RPOs.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss4-1400638">
Parts Information
Parts required to complete this Special Policy are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" prior to ordering parts. Normal orders should be placed on a DRO=Daily Replenishment Order. In an emergency, parts should be ordered CSO=Customer Special Order.
Part Number
Description
Qty/ Vehicle
12345382
Sealant, Thread, Med. Strength (6 ML)
As required
TBD*
Cleaner, Top Engine (24 ml)
If required and available
TBD*
Cleaner, Top Engine (15 oz)
24 ml (12346535 size alternative)
12345104
Cleaner, Port Fuel Injector (20 oz)
If required
15050573
Asm-Fuel Tank Fill Pipe (97-99 M/L Van)
1, if required
15747585
Asm-Fuel Tank Fill Pipe (99 C/K E63 w/o AC7)
1, if required
15747588
Asm-Fuel Tank Fill Pipe (99 C/K E62 w/o AC7)
1, if required
12568332
Assy, V6 Fuel Injector
1, if required
88894355
Bracket, V6
1, if required
17113215
Kit, V6 Seal
1, if required
93441235
Assy, V8 Fuel Injector
1, if required
93442096
Bracket, V8
1, if required
17113206
Kit, V8 Seal
1, if required
*Top engine cleaner part number 12346535 and 1050002 are no longer California compliant. California dealers will be notified via a DCS message when new alternative cleaner part numbers become available.
Important: Isuzu Parts Ordering: In order to comply with the 10-digit Isuzu part numbering system, Isuzu deaelrs must add an "8" to the beginning and a "0" to the end of the listed 8-digit part numbers when ordering parts through AIPDN.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss5-1400638">
Customer Notification
Customers will be notified of this Special Policy on their vehicles by General Motors (see copy of typical customer letter included with this bulletin-actual divisional letter may vary slightly).
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss6-1400638">
Service Procedure
System Check Use strategy-based diagnoses listed in the front of the Driveability and Emissions section of the Service Manual. If the SCPI system is operating properly, inform the customer that the vehicle does not have the condition listed in the owner letter. If poor driveability conditions persist, inform the customer that any further diagnosis and repairs will be at their expense if the vehicle is outside the parameters of the New Vehicle Warranty.
SCPI Injector Cleaning Procedure If diagnosis leads to sticking poppet nozzles, first check GMVIS to determine if the vehicle had a previous claim for injector cleaning under labor claims J5645, T5534 or T5540. If any of these three repair claims are listed, do not clean the injectors, but rather replace the engine SCPI fuel assembly with the MFI fuel assembly. If none of these three repair claims is listed, use the service procedure from Service Bulletin 00-06-04-003B to clean the SCPI poppet nozzles. Please note that the service bulletin term for SCPI is Central Sequential Fuel Injection (CSFI), but is referring to the same fuel system assembly.
SCPI Fuel Tank Fill Pipe Assembly for 1997-99 M/L Van and 1999-some 2000 C/K Truck; with 4.3L, 5.0L, 5.7L engines and built prior to listed VIN/Production dates on Service Bulletin 00-06-04-018 If diagnosis leads to sticking poppet nozzles on these models, use the service procedure from Service Bulletin 00-06-04-018 to replace the fuel tank fill pipe assembly, if this procedure has not been performed previously. Previous service procedure can be verified by checking GMVIS for Labor Operation L1065 on M/L trucks with replacement part number 15050573; or Labor Operation L1065 on C/K trucks with replacement part numbers 15747585 or 15747588.
Correction If, AFTER cleaning the SCPI poppet nozzles, the normal service manual diagnosis still indicates that the SCPI is the cause of the customer complaint, or if the injectors have previously been cleaned and the vehicle has again experienced sticking poppet nozzles, refer to Service Bulletin 00-06-04-003B and replace the SCPI fuel assembly with the MFI fuel assembly. Please note that the service bulletin term for SCPI is Central Sequential Fuel Injection (CSFI), but is referring to the same fuel system assembly.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss7-1400638">
Claim Information
For vehicles repaired under this special policy, submit a claim with the information indicated below.
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labor Hours
System Check-No SCPI Repair Needed
NA
NA
NA
MK-95
T5532
0.0-0.3 hr
Clean Fuel Injectors per Service Bulletin 00-06-04-003B:
MK-95
T5540
S/T Truck
1.3 hrs
M/L Truck, P Truck, W4 Truck
1.0 hr
C/K Truck
1.3 hrs
G Van
1.5 hr
Replace Fuel Tank Fill Pipe Asm.
MK-95
T5557
1997-99 M/L Van
0.8**
1999 and some 2000 C/K Truck
Use published labor operation time
Replace SCPI fuel system with a new MFI fuel system per Service Bulletin 00-06-04-003B
MK-95
T5576
1.4 hrs
M/L Van only
add 0.2 hr
* -- The "Parts Allowance" should be the sum total of the current GMSPO Dealer Net price plus applicable Mark-Up for SCPI/CSFI parts, fuel tank filler hose and gasket needed to complete the repair.
** -- This labor time is a change to the current Labor Time Guide. The next update of the Labor Time Guide will include this change.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss8-1400638">
Customer Reimbursement
Customer requests for reimbursement are for any previously paid repairs to, or replacement of, the Sequential Central Port Fuel Injection (SCPI) system. Repairs must have occurred within 10 years of the date the vehicle was originally placed in service, or 200,000 miles, whichever occurs first. The requests are to be submitted within two (2) years of the date on which the repair was paid or within two (2) years of the date of this Special Policy Bulletin, whichever is greater.
When a customer requests reimbursement, they must provide the following:
• Proof of ownership at the time of the repair
• Original paid receipt confirming the amount of the unreimbursed repair expense(s) (including Service Contract deductible), a description of the repair, the date repaired, and the person or entity performing the repair
Customers from the State of California must submit requests for reimbursement directly to (divisions) per instructions in the owner letter.
If the work was done by someone other than a GM dealership, the amount of reimbursement will generally be limited to the amount that the repair would have cost GM to have it completed by a GM dealership.
April, 2003 Dear General Motors Customer:
As the owner of a 1996, 1997, 1998, 1999, 2000, 2001, 2002 model year S/T, M/L, C/K, G, P, W4/NPR truck or 2003 model year NPR truck that is registered California, equipped with a 4.3L V6, 5.0L V8 or 5.7L V8 engine, and California emissions, your satisfaction with our product is very important to us. Your vehicle was provided with a new vehicle warranty, which covers certain parts of your vehicle for a specific period. These warranties are of considerable value to you if you should experience problems with your vehicle.
This letter is intended to make you aware that some owners of 1996, 1997, 1998, 1999, 2000, 2001, 2002 model year S/T, M/L, C/K, G, P, W4/NPR trucks and 2003 model year NPR trucks that are registered in California, equipped with 4.3L V6, 5.0L V8 or 5.7L V8 engine, and California emissions, may experience a Service Engine Soon light, misfire, rough idle or hard start due to a deposit build up on the Sequential Central Port injector (SCPI) poppet valve(s). The deposit build up may cause injector poppets to stick closed. Certain fuels have been found to interact with the SCPI system to cause the deposits.
This is not a recall. Do not take your vehicle to your General Motors dealer as a result of this letter unless you believe that your vehicle has the condition as described above.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss9-1400638">
What We Have Done
To address the above-mentioned condition, General Motors is providing special warranty coverage to owners of applicable vehicles registered in California. If the SCPI system failure condition occurs on your 1996, 1997, 1998, 1999, 2000, 2001, 2002 S/T, M/L, C/K, G, P, W4/NPR truck or 2003 model year NPR trucks within 10 years of the date your vehicle was originally placed in service or 200,000 miles, whichever occurs first, the condition will be repaired for you at no charge . Other conditions that may cause similar or different driveability complaints, or cause a Malfunction Indicator Light illumination, that are not a result of SCPI system failure are NOT covered by this special policy. However, you will not be charged for performing a system check when determining that the SCPI system is not the cause. Any repairs made outside the normal warranty coverage due to other conditions would be your responsibility, if you elect to have your dealer provide the service.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss10-1400638">
What You Should Do
Repairs and adjustment qualifying under this special coverage must be performed by a <Division> dealer. You may want to call the service department at the dealer to find out how long they will need to have your vehicle so that you may schedule the appointment at a time that is convenient for you. This will also allow your dealer to order parts if they are not already in stock. Keep this letter with your other important glovebox literature for future reference.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1400638&psdid=51&evc=sm#ss11-1400638">
Reimbursement
If you have already paid for some or all of the cost to have the SCPI fuel system repaired or replaced, and you have not received reimbursement under a Vehicle Service Contract, and the in-service time and mileage was less than 10 years and 200,000 miles, you should write to your (divisional specific address) to seek reimbursement. Please provide your original paid receipts or invoices verifying the repair, the amount charged, proof of payment, the date of payment of those charges and proof of ownership of the vehicle at the time of the repair. This information must be provided within two (2) years of the date on which you paid for the repair or within two (2) years of the date of this Special Policy Bulletin, whichever is greater.
If you have any questions or need any assistance, just contact your dealer or the appropriate Customer Assistance Center at the number listed below:
Division
Number
Deaf, Hearing Impaired, or Speech Impaired*
Cadillac
1-800-458-8006
1-800-833-2622
Chevrolet
1-800-222-1020
1-800-833-2438
GMC
1-800-462-8782
1-800-462-8583
Oldsmobile
1-800-442-6537
1-800-833-6537
Isuzu Medium Duty
1-800-862-4389
* Utilizes Telecommunication Devices for the Deaf/Text Telephones (TDD/TTY)
We are sorry for any inconvenience you may experience; however we have taken this action in the interest of your continued satisfaction with our products.
General Motors Corporation
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gifWE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
So you replaced the hole injector connector! Wow that is alot of wire crimps. I hope you did a good job cuz it's possible you created more problems doing that. Put to you this way for the 12 years doing this I have never replaced a injector connector on a 5.7, but I have replaced tons of injector units. I'll post the schematic on the injector connector so you can double check it and also post a bull the I think MAY help you. :fume:
Thanks for this information!
I did this change because the old connector was broken and it didn't came with the top protector, the old owner lost this... :uhoh: and also because one cilinder wasn't working, I did some test on the injector connector pushing the cables down and after that the cilinder start working again and the check engine light dissapear...I changed the connector very carefully making sure that I didn't mix any cables :M16:
Well the situation is this, after a week I start up the engine and it seems and sound OK, now the 8 cilinders are working fine and after a couple of miles the engine is very smooth...BUT after this, the check engine light went on again, I need to scan the computer to see what's the problem...I think maybe the oxigen sensor or something minor is reporting an error to the computer.
Thanks again for the information! I will update this thread when I know what's the problem!
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
