Serpentine Belt 1998 Cheyenne
i bought this 1998 cheyenne pickup 4x4, swaped everything off my 97 z71 including 3in body lift, so i removed my fan shroud and it somehow dissapeared i need the belt diagram so i can replace my serpentine belt anyone have the pic of the belt pattern?????
