The Frikkin' Giants Win?
Zembonez
Man... I can't believe the Giants beat Green Bay at home in the freezing below zero cold. I though Brett would bring his A game. Now we can skip the Yawner Bowl... The Patriots should be able to win unchallenged. The Pack was our only hope for a real excitement filled Superbowl this year...
Oh well... I guess I'll just take the boat to the lake.
Sounds like a plan what lake are we going to? :thumbs::thumbs:
Judging from the bass in your avatar pic, I'd bet we would have a great day fishing.
I wouldnt bash the Giants yet. The last time they played they gave the Pats a run for their money. As long as Eli can be consistant and the receivers make the plays as they just did, they can do it. Also the Giants' defense is pretty tough too.
I think they'd have a much better chance if Shockey was healthy. I'm pretty sure I'll watch it anyway.... Just wish ol Brett was in there.
EDIT: Because I am too stupid to use spell check!
Anyone but the Pats !! GOOOOOO GIANTS !
Sort of like the upcoming Presidential election... I'm for ANYBODY but those in there.
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 788 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
