1998 Gmc Sierra Hard Cold Start Problem
blue-ss-camaro
Like is in the title Its a 98 5.7 new cap rotor plugs wires . Has a cold start problem only when its about 40 and below. One day didnt start at all. When you turn the key on and try to start it and t doesnt start the fuel pump will run forever when you turn the key off. Today try to start it shut it off and the pump ran for like a minute and a half. Any ideas on what the problem is????
ANYBODY???
I would like to see a scan tool reading of the coolant sensor to see if it`s at least close to the ambient temp. before starting. Also, you might want to take it out to see if there`s gunk on the tip.
Check your oil pressure sending unit located on the back of the engine just to the right of the distributor.
If your full pump stays running after you shut of your truck that is why. It is probaley leaking oil out of were the connector plugs in.
Ok so I replaced the coolant sensor and I checked the fuel pressure. when I turned the key on it pressureized to 60 lbs and when I started the truck it was at a steady 52-53. Lets It sit for about 2 1/2 hours and it dropped to 50 I am woundering if it is suppose to drop???
The fuel pressure drop is fine.
You stated the fuel pump will stay on at times after the truck is shut off correct?
If that is correct the only sensor that will keep the fuel pump running after it is shut off is the oil pressure sending unit
yes i figured out that when it stays running is when I crank the engine for a long time nd it does not start thus creating oil pressure... cause the fuel pump to run when the truck does not run. Latly I have been turning the truck over once for about 3-5 sec. trying it again for about 6-8 sec then let the fuel pump run and on the third time it will start usaually. I am wondering what the pressure should be in the morning when I try to start it. I am certain I have a pressure leak just not sure where to start....
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
