What Type Of Fuel Will It Run
I AM NEW TOTHE DIESEL TRUCKS AND I JUST BOUGHT A 2007 CHEVY 3500 CLASSIC DURAMAX AND WAS WONDERING WHAT TYPE OF FUELS I SHOULD RUN AND IF I SHOULD REALLY RUN ADDITIVES. I ALSO WORK ON A LAND DRILLING RIG AND WAS WONDERING IF I CAN RUN OFFROAD DIESEL(RED FUEL) IN IT. THANKS IN ADVANCE FELLOWS.
I run 3gallons of biodiesel for each tank plus powerservice cetane booster. You should run the ULSD (#2) 15ppm. I ran the Low sulfer once, 500ppm with no problem. You probably wouldn't want to make a habit out of it though.
Its highly illegal for one. Two, any time the truck is brought in to the dealer for engine service you take a chance they will notice the dye. They can give you some flak about and not cover the work under warranty.
:thumbs:
:thumbs:
The owners manual and the sticker on the fuel door states that this engine is to run on Ultra Low Sulfer Diesel. Which I purchase at the local Shell station. The only time I ran Low Sulfer Diesel was when I was on a trip and could not find ULSD in the small town I was in. If you run a fuel with the red dye you run the risk of huge fines because no highway taxes are being paid. There was a guy on another forum that got caught and the authorities hounded him, because when you get caught once they will keep coming after you to make sure you are using legal fuel. The filters retain the dye stain and if the dealer sees this he could cause you problems.
Its fine to run dyed diesel in your truck as long as you never take it on the road. If you get caught with red fuel on the highway be prepared for some huge fines.
And RHC he is talking about dyed diesel not ulsd, plus he didnt mean anything bad by the im with stupid thing, its just a way of agreeing with you.
You can run the offroad dyed fuel all you want, as long as youre a farmer. DOTs usually wont check a diesel pickup unless youre pulling one hell of a load!. I think all pumps, other than the OFFROAD FUEL. now only have #2 diesel fuel ULSD (ultra low sulfer diesel) or are in the process of changing over to it.
One definite additive I run is HOWES DIESEL Lubricator. Mainly in the winter like months.
That never works for us.
At first glance that can be taken the wrong way, but after thinking about it I came to the same conclusion. My initial response was pretty cutting, but I edited it after I thought about it. Thanks. Richard
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
