Vibration / Hum Under Load
RaysZ71
'99 suburban 4wd.
Sounds normal till about 45 then i get this vibration humming noise and it gets louder till about 70 then it quiets down at 75. Louder under load.
I am thinking u joints. The tires are not out of balance, but may be wearinf strange. (they are firestones)
any other things to check?
