Cluster Change
grasshopper
Is there any additional programming, besides having the odomenter and hours reset to match the removed cluster, required when the cluster is changed? Are there any special tools required for this job? I've had the clusters out on earlier GM trucks, but I am not familiar with the '08.
Can you provide me with the correct P/N for a '08 KPH Cluster?
Cheers,
Butch
    • *Your
