Need Help / Truck Won't Start
Hi Friends,
I have a problem I need help with figuring out. My 99 GMC Suburban won't start. Well it won't stay running. It will start and stall immediately. Several years ago, I'm guessing 40K miles ago, I had the fuel pump replaced under warranty. The problem seems identical. Also about a year ago my fuel gage needle started to vibrate, a fast vibrate. Since I am not under warranty now I need to fix this myself and get the family truck running again.
1) I believe I have spark since it will fire up, but stalls immediately. So I want to rule out ignition issues.
2) I need to verify fuel pressure to make sure the pump is working correctly.
Questions:
What is the correct operating fuel pressure supposed to be?
Could the vibrating fuel needle be a failing / failed fuel sending unit that won't allow the truck to stay running?
Any suggestions, comment and hints would be greatly appreciated.
Thanks
teamjnz
Can't answer your questions directly, but immediately after replacing the fuel pump on my '99 Chev Suburban (at about 150K), the fuel needle vibrated. It never did that at all before but did it continuously afterwards and it never seemed to cause a problem. Fuel level was accurate, new fuel pump cured the whining sound but the fuel needle vibrated all the time.
When my fuel pump died, the vehicle would not start at all. I'm sure there are different problems within the pump that could cause both symptoms (won't start and run w/ stall).
Hi Friends,
Questions:
Thanks
teamjnz
What engine do you have in it?
Strange that the needle starts to vibrate after the new fuel pump installation.
The motor is a 5.7L
Thanks Guys...
This should help you.
Document ID# 372304
1999 Chevrolet Chevy Suburban - 2WD
Fuel System Diagnosis
Circuit Description
When the ignition switch is turned ON, the Vehicle Control Module (VCM) energizes the fuel pump relay which powers the in-tank fuel pump ON. The pump remains ON as long as the engine is cranking or running and the VCM is receiving reference pulses. If there are no reference pulses, the VCM shuts the fuel pump OFF within 2 seconds after the ignition was switched to the ON position or if the engine stops. The VCM will also turn ON the fuel pump for 2 seconds when the ignition is turned to the OFF position.
An electric fuel pump pumps the fuel through an in-line filter to the Central SFI unit. The pump is attached to the fuel level meter assembly inside of the fuel tank. The pump is designed to provide fuel pressure above what is needed by the fuel injectors. The pressure regulator keeps the fuel available to the injectors at a regulated pressure. Unused fuel is returned to the fuel tank by the fuel return pipe.
Diagnostic Aids
Tools Required
J 34730-1A Fuel Pressure Gauge with J 34730-250 Fuel Pressure Adapter Kit.
J 42873-1 and the J 42873-2 .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Wrap a shop towel around the fuel pressure connection to absorb any small amount of fuel leakage that may occur when installing the fuel pressure gauge. Turn ON the ignition leaving the engine OFF, the fuel pressure should be 415-455 kPa (60-66 psi) when the pump is running. This pressure is controlled by a spring pressure within the regulator assembly.
The fuel pressure that continues to fall is caused by one of the following items:
- The in-tank modular fuel sender is not holding pressure.
- The fuel pressure regulator valve is leaking.
- A Central SFI injector is leaking.
- Fuel line is leaking.
If the fuel pressure is less than 379 kPa (55 psi) at idle, it falls into the following 3 areas:
- The pressure is regulated but less than 379 kPa (55 psi).The amount of fuel reaching the injector is sufficient, but the pressure is too low. The system will run lean, hard starting cold, no start, overall poor performance, and may set a DTC. Refer to Engine Cranks but Does Not Run
- A restricted flow causing pressure drop -- Normally, a vehicle with a fuel pressure of less than 300 kPa (44 psi) at idle is inoperable. However, if the pressure drop occurs only while driving, the engine will normally surge then stop running as the pressure begins to drop rapidly. This is most likely caused by a restricted fuel line or plugged filter.
- A leaking or contaminated pressure regulator valve or seat interface may not allow the regulated pressure to be achieved.
Notice: DO NOT allow the fuel pressure to exceed 517 kPa (75 psi). Excessive pressure may damage the fuel system.
Restricting the fuel return line allows the fuel pressure to build above regulated pressure. With the fuel pump commanded ON, the fuel pressure should rise above 455 kPa (66 psi), as the valve in the return line is partially closed.
When the engine is idling, the manifold pressure is low (high vacuum) and is applied to the fuel pressure regulator diaphragm. This will offset the spring and result in a lower fuel pressure. This idle pressure will vary somewhat depending on the barometric pressure; however, the pressure at idle should be less indicating the pressure regulator control.
If the injector(s) is not grounded, physically remove suspect injector(s) and inspect for a fuel leak while system is pressurized. If the fuel injector(s) are not leaking and fuel pressure is not holding, the fuel pressure regulator should be inspected for a slow diaphragm leak.
Step
Action
Value(s)
Yes
No
Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Caution: The fuel pump will operate for 2 seconds after you have turned off the ignition. Make sure that all the fuel pipes and fittings are securely fastened in order to prevent personal injury.
Turn OFF the ignition.
Relieve the fuel pressure. Refer to Fuel Pressure Relief Procedure .
Caution: Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
Install the fuel pressure gauge J 34730-1A or the equivalent.
Using the scan tool, command the fuel pump ON.
Bleed the air out of the fuel pressure gauge into an approved gasoline container.
Monitor the fuel pressure with the fuel pump running. It should measure within the specified value.
Important: The fuel pump may have to be commanded ON more than once in order to obtain the maximum fuel pressure.
Is the fuel pressure within the specified value?
Central SFI - 413-455 kPa (60-66 psi)
Go to Step 3
Go to step 8
3
After the pump stops, does the fuel pressure hold steady within the specified value?
Central SFI - 379-413 kPa (55-60 psi)
Go to Step 5
Go to Step 4
4
Caution: Place a dry chemical (Class B) fire extinguisher nearby before performing any on-vehicle service procedures. Failure to follow these precautions may result in personal injury.
Caution: Provide proper ventilation when working with fuel in enclosed areas where fuel vapors can collect. The lack of adequate ventilation may result in personal injury.
Disconnect the fuel filter.
Drain any remaining fuel from the fuel pipes into an approved gasoline container.
Install the J 42873-1 in the place of the fuel filter.
Open the valve on the fuel pipe shut-off adapter.
Check for any leaks at the fuel shut-off adapter fittings.
Start the engine and let idle for 30 seconds.
Turn ON the ignition leaving the engine OFF.
Wait for the fuel pressure to build.
Close the valve in the fuel feed pipe shut-off. The pressure should remain constant.
Does the fuel pressure remain constant within the specified value?
Go to Step 12
Go to Step 6
5
Is the fuel pressure suspected of dropping-off during acceleration, cruise, or hard cornering?
Go to Step 27
Go to Step 26
6
Inspect the fuel feed line between the shut-off adapter and the engine fuel pipes.
Was a problem found?
Go to Step 25
Go to Step 7
7
Open the valve in the fuel feed pipe shut-off adapter.
Disconnect the fuel return pipe union fitting located near the fuel filter.
Install the J 42873-2 in the place of the fuel return pipe union.
Open the valve in the fuel return pipe shut-off adapter.
Close the valve in the shut-off adapter that is connected to the fuel return pipe.
Does the fuel pressure remain constant?
Go to Step 22
Go to Step 29
8
Using the scan tool, command the fuel pump ON.The fuel pump should operate for 2 seconds and then turn off.
Monitor the fuel pressure after fuel pump stops running.
Is the fuel pressure present?
Go to Step 13
Go to Step 9
9
Turn ON the ignition.
Listen for the fuel pump running.
Does the fuel pump run?
Go to Step 10
Go to Fuel Pump Electrical Circuit Diagnosis
10
Check for the following conditions:
• No fuel in the fuel tank (do not rely on fuel gauge reading)
• Plugged in-line fuel filter
• Plugged or damaged fuel pump strainer
• Restricted fuel line
On dual tank models, check the auxiliary tank for fuel. If no fuel is present, refer to DTC P0461 Fuel Level Sensor Performance .
Go to Step 11
Go to Step 12
11
Repair or replace as necessary.
Is the action complete?
Go to Step 30
12
Check for a leaking fuel feed pipe in between the shut-off adapter and the modular fuel sender, if no leak is present, replace the modular fuel sender. Refer to Fuel Sender Assembly Replacement .
Go to Step 30
13
Monitor the fuel pressure while the pump is running.
Is the fuel pressure above the specified value?
Central SFI - 455 kPa (66 psi)
Go to Step 14
Go to Step 15
14
Disconnect the engine compartment fuel return line
Attach a flex hose to the fuel return line.
Insert the other end into an approved gasoline container.
Using the scan tool, command the fuel pump ON while monitoring the fuel pressure.
Is the fuel pressure within the specified value while the pump is running?
Go to Step 16
Go to Step 17
15
Is the fuel pressure below the specified value?
Central SFI - 413 kPa (60 psi)
Go to Step 19
Go to Step 30
16
Locate and correct the restriction in the fuel return line.
Go to Step 30
Go to Step 17
17
Visually and physically inspect the engine fuel return outlet pipe (where the fuel line was disconnected) for restriction.
Was a restriction found?
Go to Step 18
Go to Step 22
18
Replace the engine fuel pipes. Refer to Fuel Hose/Pipes Replacement - Engine Compartment .
Go to Step 30
19
Perform the following items:
• Check for a restricted fuel line.
• Check for a restricted in-line fuel filter
Go to Step 20
Go to Step 21
20
Repair or replace as necessary the following items:
• The restricted fuel line
• The restricted fuel line filter
Go to Step 30
21
Disconnect the fuel return pipe union located near the fuel filter.
Open the valve on the fuel return pipe shut-off adapter.
Using the scan tool, again command the fuel pump ON.
Slowly close the valve on the fuel return pipe shut-off adapter while the pump is running. The pressure should rise above the specified value.
Does the fuel pressure rise above the specified value?
Go to Step 22
Go to Step 23
22
Replace the fuel pressure regulator. Refer to Fuel Pressure Regulator Replacement .
Go to Step 30
23
• Check for low fuel pump voltage due to high resistance connections
• Check for high fuel pump voltage due to internal pump binding
• Check for a poor fuel pump ground
• Check for a partially restricted fuel pump strainer
• Check for an incorrect fuel pump
• Check for a faulty fuel pump
Go to Step 24
Go to Step 12
24
Go to Step 30
25
Replace the fuel feed line.
Go to Step 30
26
Start the engine.
Idle until the engine reaches the normal operating temperature.
Open the throttle quickly.
Monitor the fuel pressure.
The fuel pressure should approach the top of the specified range.
Does the fuel pressure rise quickly?
Go to Driveability Symptoms
Go to Step 27
27
Visually and physically inspect the following items for a restriction:
The in-line fuel filter for restriction.
The fuel feed pipe.
The fuel pump strainer must not be damaged or mispositioned.
The fuel pump flex pipe for leaks.
Verify the fuel pump is the correct fuel pump for this vehicle.
The fuel pump electrical wiring for high resistance.
Was a problem found in any of these areas?
Go to Step 28
Go to Step 12
28
Repair the problem as necessary.
Go to Step 30
29
Locate and replace any leaking or grounded injector(s). Refer to Test Description for this step.For grounded injector diagnosis, refer to Fuel Injector Circuit Diagnosis .
Go to Step 30
Go to Fuel Injector Balance Test with Tech 2
30
Use the scan tool in order to display the Capture Information and the Review Capture Information function.
Are there any DTCs displayed that have not been diagnosed?
Go to the applicable DTC table
System OK
