Ignition Switch Problem
alcolee
I'm not sure if I know all the proper terminology for what I'm talking about, but I'll be as descriptive as I can. My friend has an '01 ext-cab Silverado. On occasion the truck would not crank, the battery was fine, and all the interior lights and guages would come one, but when you turned the key, nothing. We were advised by a couple different mechanics to replace the electronic ignition switch - the one residing inside the steering column that mounts to what appears to be the bottom of the key cylinder. We followed the directions in the service manual to remove the old one, and then replaced it with a new one. We have the switch in the correct position, and as best we can tell, followed all the proper steps, however we still have a problem. When you try to turn the key, you get the first to key positions, and then the key stops. It will go into that final position of rolling forward to actually start the truck. It will go just a hair past the second position, but then it hit a brick wall. I don't know if this means anything, but the truck also flashes security when the key is off???? What are we missing? Is there something we have to reset in order to allow the key to function properly? Please help us out, we are beyond frustrated at this point. Are next step will be to try and push or winch this big truck onto a trailer and tow it to a mechanic. Thanks for the help.
no body has any ideas???? This truck is sitting dead in my driveway right now and the dude is bumming rides until we figure this out. On one of the other ignition discussions, someone said something about there being a resistor swith in the wiring harness that had to be reprogramed by the dealer if it was changed. Is there any truth to this? Please help us out.
I think there is a bind or a misalignment of the ignition switch rod. The original problem might have been something in the starter crank circuit. The same thing happened to my dad's 78 GMC. The purple starter wire got loose of the S terminal of the starter and did the same thing you did was replace the ignition switch but it was a loose starter crank wire. I would check the park/neutral switch or clutch safety switch for proper operation. Gm did not change that circuit from the 1978 to 2005 trucks. Even the same color wiring. Also there is no computer involved with ANY of the crank circuit. Just the fuel pump anti theft PASSLOCK.
I guess it's possible, but I wouldn't start in the morning and we moved the tilt steering column and it started right up. That's why we're pretty sure it was something electrical inside the steering column. Also, even if it was a loose wire on the starter, that wouldn't explain why the key wouldn't turn past the second position. Thanks for the reply though.
you may have a security code and should not take it to a mechanic,take it to a technician at a dealer and let them fix your mistake,how much money have you guys saved ,no more backyard fixes boys ,sorry.
It is bind in the rod that moves the ignition switch and the movement of the tilt confirms that. There is only two wires that go the a lock cylinder for the PASSLOCK and everything else is controlled by the rod that moves the slider in the ignition switch.
Yeah no more easy fixes. Need to tear into the column to find the bind or electrical problem.
There is no rod. The switch is a tooth off.
ok, the truck is back together and running and starting like normal, no programming, no code issues. The fix was actually very simple. Once we got the electrical switch in the correct position, it was just a matter of putting the key cylinder back in the correct position. Once we put the cylinder in, we twisted it back just a fraction of an inch before locking it into position and everything worked perfectly. And to answer your question, yes we saved quit a bit of money doing this ourselves, and had we known the last step of positioning the key cylinder properly, we probably could have replaced this switch in a couple hours or less. Thanks for the help though.
That's what I said you were a tooth off.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 649 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
