jrrod2004 Posted January 31, 2008 Posted January 31, 2008 VIN : 1GTGC23U64F203770 VEHICLE INFORMATION Merchandising Model : TC25743 -2004 SIERRA 2500 LD 2WD CREW CAB Warranty Start Date : 03/24/2005 BARS Order Type : 70 - RETAIL - STOCK Delivering Dealer : WESTCOTT BUICK-PONTIAC-ISUZU-GMC, INC. PO BOX 1598 BURLINGTON , NC 27216-1598 (336) 228-0141 Selling Source : 48 - GMC TRUCK Site Code : 10045 Business Associate Code : 118215 Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid REQUIRED FIELD ACTIONS Type Number Description Posted Date Status RC 04019 4L80E/4L85E TRANS LOSS OF INTERNAL LUBRICATION - **EXPIRED 3/31/05 - CLOSED** ?? N/A Closed RC 05006 HYDRO-BOOST ACCUMULATOR OVER-PRESSURIZATION ?? N/A Closed RC 05037 SECOND ROW CENTER SAFETY BELT ?? N/A Closed SERVICE INFORMATIONAL ITEMS Type Number Description Posted Date Status SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. ?? 02/21/2007 See Bulletin ON STAR AND XM SATELLITE RADIO INFORMATION OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271. XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677). APPLICABLE WARRANTIES Description Effective Date Effective Odometer End Date End Odometer 36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/24/2005 85 miles 03/24/2008 36085 miles 72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/24/2005 85 miles 03/24/2011 100085 miles 96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/24/2005 85 miles 03/24/2013 80085 miles 60/50000 FEDERAL EMISSION 03/24/2005 85 miles 03/24/2010 50085 miles CLAIM HISTORY R.O Date R.O Number Type Labor Operation Odometer Reading 11/03/2007 129076 # C3541 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 35033 miles 11/03/2007 129076 # C3540 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 35033 miles 07/20/2007 125376 # C6051 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - SPLIT/DIVIDED SEAT - 30009 miles 07/13/2007 125145 0 M0015 - LUBE, OIL AND FILTER 29682 miles 07/13/2007 125145 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 29682 miles 03/06/2007 120757 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 23393 miles 03/06/2007 120757 # L2584 - MUFFLER - SINGLE - REPLACE 23393 miles 03/06/2007 120757 # Z7901 - 1-DAY COURTESY TRANSPORTATION 23393 miles 12/27/2006 118401 0 M0014 - LUBE, OIL AND FILTER 21046 miles 12/27/2006 118401 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 21046 miles 10/21/2006 116231 # C3361 - PLATE AND/OR INSERT, FRONT DOOR SILL - LEFT - REPLACE 18623 miles 10/21/2006 116231 # C3358 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 18623 miles 10/09/2006 115756 # C6628 - ACTUATOR AND/OR ASSEMBLY, LUMBAR - LEFT - REPLACE 17295 miles 09/23/2006 115296 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 16884 miles 07/14/2006 091713 # K7000 - TRANSMISSION ASSEMBLY - REPLACE 13778 miles 07/05/2006 E39933 # Z2080 - ROADSIDE SERVICE (TOWING) 13700 miles 07/05/2006 091713 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 13778 miles 07/05/2006 091713 # H9991 - CUSTOMER CONCERN NOT DUPLICATED 13778 miles 06/16/2006 111773 # C4283 - MOLDING, BACK WINDOW GARNISH - LOWER - R&R OR REPLACE 11994 miles 06/16/2006 111773 # K9995 - CUSTOMER CONCERN NOT DUPLICATED 11994 miles 02/25/2006 107760 # B7288 - HEADLAMP/COMPOSITE ASSEMBLY - RIGHT - REPLACE 10045 miles 02/18/2006 107523 # C2601 - BODY HINGE PILLAR TRIM PANEL REPLACEMENT - LEFT SIDE 8012 miles 02/03/2006 106995 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 8006 miles 02/03/2006 106995 D N4180 - INSTRUMENT CLUSTER REPLACEMENT 8007 miles 12/27/2005 105249 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 6832 miles 12/15/2005 105249 # V1308 - 05006 - INSPECT HYDRO-BOOST - NO FURTHER ACTION REQURIED 6832 miles 12/15/2005 105249 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 6832 miles 11/16/2004 089879 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 57 miles 11/16/2004 089879 # J5650 - FUEL INJECTOR REPLACEMENT 57 miles 02/23/2004 A03770 G Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles 02/23/2004 A03770 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles ? 1998-2005 General Motors Corporation. All Rights Reserved. VIN 1GTGC23U64F203770 VEHICLE BUILD Merchandising Model : TC25743 -2004 SIERRA 2500 LD 2WD CREW CAB Gross Vehicle Weight Rating : 3904 kg (8608 lb) Order Number : GZKHBQ Build Date : 02/23/2004 Build Plant : 14F43 GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. OPTION CODES AG1 - POWER DRIVER SEAT ADJUSTER AG2 - POWER FRONT SEAT ADJUSTERS AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT AN3 - FRONT BUCKETS W/POWER ADJUSTER AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS A31 - POWER WINDOWS B30 - FULL COLOR KEYED CARPET W/MATS B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR-KEYED FLOOR MATS B71 - WHEEL FLARES B85 - BLACK BODYSIDE MOLDINGS CJ2 - AIR COND., DUAL ZONE AUTOMATIC CMD - ASSEMBLY PLANT - FLINT, MI C49 - ELECTRIC REAR WINDOW DEFOGGER C6P - GVW RATING - 8,600 LBS DF5 - ISRV MIRROR W/COMPASS & TEMP DK7 - CUSTOM INTERIOR ROOF CONSOLE DL3 - EXTERIOR MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL DT4 - SMOKER'S PACKAGE D07 - FLOOR CONSOLE EVA - EVAP EMISSION REQUIREMENT E63 - WIDESIDE BODY FE9 - 50-STATE EMISSIONS FT2 - ARM TORS BAR SPRING ADJ FT3 - ARM TORS BAR SPRING ADJ GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING REAR DIFFERENTIAL JH6 - 4 WHEEL POWER DISC BRAKES, HD KC4 - ENGINE OIL COOLING SYSTEM KNP - H.D. TRANSMISSION OIL COOLER KUP - THROTTLE CONTROL ELECTRONIC K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER K68 - ALTERNATOR 105 AMP LQ4 - VORTEC 6000 V8 SFI GAS ENGINE MT1 - 4 SPEED AUTO TRANS W/OVERDRIVE AND ELECTRONIC CONTROL NA4 - EMISSION SYSTEM-HEAVY DUTY NP5 - LEATHER WRAPPED STEERING WHL NT9 - EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT PY0 - POLISHED ALUMINUM WHEELS QIZ - LT245/75R16/E ALS BW TIRES R9Z - POMS EXPEDITE-SOLD ORDERS SLM - STOCK ORDERS TFE - SALES INCENTIVE-COMMITMENT PLUS T96 - FRONT FOG LAMPS UC6 - AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPEAKER SYSTEM UE1 - ONSTAR COMMUNICATION SYSTEM INCL 1 YR SAFE & SOUND PLAN UK3 - STEERING WHEEL RADIO CONTROLS UK6 - REAR SEAT AUDIO CONTROLS UQ7 - BOSE SPEAKER SYSTEM VB3 - CHROME REAR BUMPER VG3 - CHROME FRONT BUMPER VR4 - WEIGHT DIST HITCH PLATFORM VXS - COMPLETE VEHICLE LABEL V22 - CHROME GRILLE SURROUND V73 - STATEMENT OF CERT. U.S. V76 - RECOVERY HOOKS XHH - LT245/75R16/E ALS BL TIRES YD3 - BASE EQUIP FOR SCH GVW PLATE YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR YHH - LT245/75R16/E ALS BW TIRES-REAR ZHH - LT245/75R16/E ALS BW TIRE-SPR ZY1 - SOLID PAINT Z82 - HEAVY DUTY TRAILERING EQUIP. Z85 - HANDLING/TRAILERING SUSPENSION PACKAGE Z88 - GMC TRUCK NAMEPLATE 1SD - SLT DECOR INCLUDES: *AIR COND. DUAL ZONE AUTO *OSRV MIRRORS W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ. HEAT, TILT & TURN SIGNAL *REAR WINDOW DEFOGGER *DEEP TINT GLASS *FRONT FOG LAMPS *AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPEAKER SYSTEM *POLISHED ALUMINUM WHEELS *ELECTRONIC SPEED CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM *ISRV MIRROR W/COMPASS & TEMP *LEATHER WRAPPED STEERING WHEEL *ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND *STEERING WHEEL RADIO CONTROLS *LEATHER APPOINTED SEATS 1SZ - OPTION PACKAGE DISCOUNT 50U - SUMMIT WHITE 6GL - SPRING COMPTR SELECT FRT LH 7GL - SPRING COMPTR SELECT FRT RH 92I - DARK PEWTER INTERIOR TRIM 922 - PEWTER INTERIOR TRIM ? 1998-2005 General Motors Corporation. All Rights Reserved.
jonesj2 Posted January 31, 2008 Author Posted January 31, 2008 Thank You for the quick response. Looking at getting a 5th wheel camper and wanted to know the full fact about the truck. Jim VIN : 1GTGC23U64F203770VEHICLE INFORMATION Merchandising Model : TC25743 -2004 SIERRA 2500 LD 2WD CREW CAB Warranty Start Date : 03/24/2005 BARS Order Type : 70 - RETAIL - STOCK Delivering Dealer : WESTCOTT BUICK-PONTIAC-ISUZU-GMC, INC. PO BOX 1598 BURLINGTON , NC 27216-1598 (336) 228-0141 Selling Source : 48 - GMC TRUCK Site Code : 10045 Business Associate Code : 118215 Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid REQUIRED FIELD ACTIONS Type Number Description Posted Date Status RC 04019 4L80E/4L85E TRANS LOSS OF INTERNAL LUBRICATION - **EXPIRED 3/31/05 - CLOSED** ?? N/A Closed RC 05006 HYDRO-BOOST ACCUMULATOR OVER-PRESSURIZATION ?? N/A Closed RC 05037 SECOND ROW CENTER SAFETY BELT ?? N/A Closed SERVICE INFORMATIONAL ITEMS Type Number Description Posted Date Status SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. ?? 02/21/2007 See Bulletin ON STAR AND XM SATELLITE RADIO INFORMATION OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271. XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677). APPLICABLE WARRANTIES Description Effective Date Effective Odometer End Date End Odometer 36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/24/2005 85 miles 03/24/2008 36085 miles 72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/24/2005 85 miles 03/24/2011 100085 miles 96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/24/2005 85 miles 03/24/2013 80085 miles 60/50000 FEDERAL EMISSION 03/24/2005 85 miles 03/24/2010 50085 miles CLAIM HISTORY R.O Date R.O Number Type Labor Operation Odometer Reading 11/03/2007 129076 # C3541 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 35033 miles 11/03/2007 129076 # C3540 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 35033 miles 07/20/2007 125376 # C6051 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - SPLIT/DIVIDED SEAT - 30009 miles 07/13/2007 125145 0 M0015 - LUBE, OIL AND FILTER 29682 miles 07/13/2007 125145 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 29682 miles 03/06/2007 120757 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 23393 miles 03/06/2007 120757 # L2584 - MUFFLER - SINGLE - REPLACE 23393 miles 03/06/2007 120757 # Z7901 - 1-DAY COURTESY TRANSPORTATION 23393 miles 12/27/2006 118401 0 M0014 - LUBE, OIL AND FILTER 21046 miles 12/27/2006 118401 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 21046 miles 10/21/2006 116231 # C3361 - PLATE AND/OR INSERT, FRONT DOOR SILL - LEFT - REPLACE 18623 miles 10/21/2006 116231 # C3358 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 18623 miles 10/09/2006 115756 # C6628 - ACTUATOR AND/OR ASSEMBLY, LUMBAR - LEFT - REPLACE 17295 miles 09/23/2006 115296 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 16884 miles 07/14/2006 091713 # K7000 - TRANSMISSION ASSEMBLY - REPLACE 13778 miles 07/05/2006 E39933 # Z2080 - ROADSIDE SERVICE (TOWING) 13700 miles 07/05/2006 091713 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 13778 miles 07/05/2006 091713 # H9991 - CUSTOMER CONCERN NOT DUPLICATED 13778 miles 06/16/2006 111773 # C4283 - MOLDING, BACK WINDOW GARNISH - LOWER - R&R OR REPLACE 11994 miles 06/16/2006 111773 # K9995 - CUSTOMER CONCERN NOT DUPLICATED 11994 miles 02/25/2006 107760 # B7288 - HEADLAMP/COMPOSITE ASSEMBLY - RIGHT - REPLACE 10045 miles 02/18/2006 107523 # C2601 - BODY HINGE PILLAR TRIM PANEL REPLACEMENT - LEFT SIDE 8012 miles 02/03/2006 106995 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 8006 miles 02/03/2006 106995 D N4180 - INSTRUMENT CLUSTER REPLACEMENT 8007 miles 12/27/2005 105249 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 6832 miles 12/15/2005 105249 # V1308 - 05006 - INSPECT HYDRO-BOOST - NO FURTHER ACTION REQURIED 6832 miles 12/15/2005 105249 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 6832 miles 11/16/2004 089879 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 57 miles 11/16/2004 089879 # J5650 - FUEL INJECTOR REPLACEMENT 57 miles 02/23/2004 A03770 G Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles 02/23/2004 A03770 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles ? 1998-2005 General Motors Corporation. All Rights Reserved. VIN 1GTGC23U64F203770 VEHICLE BUILD Merchandising Model : TC25743 -2004 SIERRA 2500 LD 2WD CREW CAB Gross Vehicle Weight Rating : 3904 kg (8608 lb) Order Number : GZKHBQ Build Date : 02/23/2004 Build Plant : 14F43 GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. OPTION CODES AG1 - POWER DRIVER SEAT ADJUSTER AG2 - POWER FRONT SEAT ADJUSTERS AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT AN3 - FRONT BUCKETS W/POWER ADJUSTER AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS A31 - POWER WINDOWS B30 - FULL COLOR KEYED CARPET W/MATS B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR-KEYED FLOOR MATS B71 - WHEEL FLARES B85 - BLACK BODYSIDE MOLDINGS CJ2 - AIR COND., DUAL ZONE AUTOMATIC CMD - ASSEMBLY PLANT - FLINT, MI C49 - ELECTRIC REAR WINDOW DEFOGGER C6P - GVW RATING - 8,600 LBS DF5 - ISRV MIRROR W/COMPASS & TEMP DK7 - CUSTOM INTERIOR ROOF CONSOLE DL3 - EXTERIOR MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL DT4 - SMOKER'S PACKAGE D07 - FLOOR CONSOLE EVA - EVAP EMISSION REQUIREMENT E63 - WIDESIDE BODY FE9 - 50-STATE EMISSIONS FT2 - ARM TORS BAR SPRING ADJ FT3 - ARM TORS BAR SPRING ADJ GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING REAR DIFFERENTIAL JH6 - 4 WHEEL POWER DISC BRAKES, HD KC4 - ENGINE OIL COOLING SYSTEM KNP - H.D. TRANSMISSION OIL COOLER KUP - THROTTLE CONTROL ELECTRONIC K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER K68 - ALTERNATOR 105 AMP LQ4 - VORTEC 6000 V8 SFI GAS ENGINE MT1 - 4 SPEED AUTO TRANS W/OVERDRIVE AND ELECTRONIC CONTROL NA4 - EMISSION SYSTEM-HEAVY DUTY NP5 - LEATHER WRAPPED STEERING WHL NT9 - EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT PY0 - POLISHED ALUMINUM WHEELS QIZ - LT245/75R16/E ALS BW TIRES R9Z - POMS EXPEDITE-SOLD ORDERS SLM - STOCK ORDERS TFE - SALES INCENTIVE-COMMITMENT PLUS T96 - FRONT FOG LAMPS UC6 - AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPEAKER SYSTEM UE1 - ONSTAR COMMUNICATION SYSTEM INCL 1 YR SAFE & SOUND PLAN UK3 - STEERING WHEEL RADIO CONTROLS UK6 - REAR SEAT AUDIO CONTROLS UQ7 - BOSE SPEAKER SYSTEM VB3 - CHROME REAR BUMPER VG3 - CHROME FRONT BUMPER VR4 - WEIGHT DIST HITCH PLATFORM VXS - COMPLETE VEHICLE LABEL V22 - CHROME GRILLE SURROUND V73 - STATEMENT OF CERT. U.S. V76 - RECOVERY HOOKS XHH - LT245/75R16/E ALS BL TIRES YD3 - BASE EQUIP FOR SCH GVW PLATE YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR YHH - LT245/75R16/E ALS BW TIRES-REAR ZHH - LT245/75R16/E ALS BW TIRE-SPR ZY1 - SOLID PAINT Z82 - HEAVY DUTY TRAILERING EQUIP. Z85 - HANDLING/TRAILERING SUSPENSION PACKAGE Z88 - GMC TRUCK NAMEPLATE 1SD - SLT DECOR INCLUDES: *AIR COND. DUAL ZONE AUTO *OSRV MIRRORS W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ. HEAT, TILT & TURN SIGNAL *REAR WINDOW DEFOGGER *DEEP TINT GLASS *FRONT FOG LAMPS *AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPEAKER SYSTEM *POLISHED ALUMINUM WHEELS *ELECTRONIC SPEED CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM *ISRV MIRROR W/COMPASS & TEMP *LEATHER WRAPPED STEERING WHEEL *ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND *STEERING WHEEL RADIO CONTROLS *LEATHER APPOINTED SEATS 1SZ - OPTION PACKAGE DISCOUNT 50U - SUMMIT WHITE 6GL - SPRING COMPTR SELECT FRT LH 7GL - SPRING COMPTR SELECT FRT RH 92I - DARK PEWTER INTERIOR TRIM 922 - PEWTER INTERIOR TRIM ? 1998-2005 General Motors Corporation. All Rights Reserved.
newcastle3 Posted January 31, 2008 Posted January 31, 2008 Don't want to hijack the thread, but just got a new truck. 2GTEK13T561159752 Thanks
kboychuk Posted January 31, 2008 Posted January 31, 2008 New to forum, would you mind running mine 1gcek19y27z575561 Thanks a lot. I just bought the truck and cannot wait to get it.
MS3DALE Posted January 31, 2008 Posted January 31, 2008 Don't want to hijack the thread, but just got a new truck. 2GTEK13T561159752 Thanks GM Vehicle Inquiry System Vehicle Build VIN 2GTEK13T561159752 VEHICLE BUILD Merchandising Model : TK15543 -2006 SIERRA 1500 4WD CREW CAB SLT Gross Vehicle Weight Rating : 3178 kg (7007 lb) Order Number : JFPM8Q Build Date : 09/12/2005 Build Plant : 26143 GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. OPTION CODES AG1 - POWER DRIVER SEAT ADJUSTERS AG2 - POWER FRONT SEAT ADJUSTERS AJ1 - DEEP TINTED GLASS AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT AM7 - FOLDING REAR SEAT AN3 - FRT FULL-FEATURE RECLINING BUCKET SEATS - LEATHER AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS A31 - POWER WINDOWS BVE - CHROME TUBULAR ASSIST STEPS ***DEALER INSTALLED*** B30 - FULL-COLOR KEYED CARPET W/MATS B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR-KEYED FLOOR MATS B71 - WHEEL FLARES B85 - BRIGHT BODY SIDE MOLDINGS CJ2 - DUAL ZONE AIR COND - AUTO C49 - ELECTRIC REAR WINDOW DEFOGGER C5W - GVW RATING - 7,000 LBS DF5 - ELECTROCHROMIC ISRV MIRROR WITH COMPASS & TEMP DK7 - OVERHEAD CONSOLE DL3 - OSRV MIRRORS W/PWR FOLD & ADJ, HEAT & TURN SIGNAL; ELECTROCHROMIC DR-SIDE MIRROR DNR - DEALER INSTALLED EQUIPMENT DT4 - SMOKER'S PACKAGE D07 - FLOOR CONSOLE EVA - EVAP EMISSION REQUIREMENT E2C - ORDER TO DELIVERY - EXPEDITE E63 - WIDESIDE BOX PICKUP BED FF6 - TORSION BAR SPRING ADJ - LH FF7 - TORSION BAR SPRING ADJ - RH GU6 - REAR AXLE - 3.42 RATIO G80 - H.D. REAR LOCKING DIFFERENTIAL JF3 - POWER DISC BRAKES W/ABS JJG - FRT END SUBASSEMBLY KG3 - ALTERNATOR 145 AMP KNP - H.D. TRANSMISSION OIL COOLER KUP - THROTTLE CONTROL ELECTRONIC K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER LM7 - VORTEC 5.3L 295HP IRON BLK V8 M30 - 4-SPD AUTO TRANS W/ OVERDRIVE NC7 - FEDERAL EMISSION OVERRIDE NE1 - 50-STATE EMISSIONS NP5 - LEATHER-WRAPPED STEERING WHL NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE NU4 - CALIF EMISSION SYSTEM LEV 2PLUS NZZ - OFF-ROAD SKID PLATE PKG OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO PDB - ONSTAR PLUS PACKAGE INCLUDES: *XM SATELLITE RADIO - SERVICE FEE EXTRA - 1ST 3 MONTHS INCL. *ONSTAR SERVICE - INCLUDES 1 YEAR SAFE & SOUND PLAN PDU P27 - 17" POLISHED CAST ALUM. WHEELS QJP - P265/70R17, OOR, BW TIRES R5C - TIRE BRAND ALL BRIDGESTONE R6J - CUSTOMER DIALOGUE NETWORK R6P - PREMIUM PAINT R9N - LEATHER SEAT TRIM R9Z - POMS EXPEDITE-SOLD ORDERS SAF - SPARE TIRE LOCK SLL - SOLD ORDERS SSB TFE - SALES INCENTIVE-COMMITMENT PLUS TSM T96 - FRONT FOG LAMPS UC6 - AM/FM STEREO W/6-DISC CD CHANGER (REPLACES STD/OPT RADIO) UE1 - ONSTAR SERVICE: INCLUDES 1 YEAR SAFE & SOUND PLAN UK3 - STEERING WHEEL RADIO CONTROLS UK6 - REAR SEAT AUDIO CONTROLS UQ7 - BOSE PREMIUM SPEAKER SYSTEM U2K - *XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. VB3 - CHROME STEP REAR BUMPER VG3 - CHROME FRONT BUMPER VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DIST HITCH PLATFORM VXS - COMPLETE VEHICLE LABEL V22 - CHROME GRILLE SURROUND V73 - STATEMENT OF CERT. U.S. XJP - P265/70R17 OOR B/W YD3 - BASE EQUIP FOR SCH GVW PLATE YD5 - FRONT SPRING - BASE EQUIPMENT YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR YJP - P265/70R17 OOR BW ZJP - P265/70R17-113S BW SPARE TIRE ZY1 - SOLID PAINT Z71 - OFF-ROAD SUSPENSION PACKAGE Z82 - H.D. TRAILERING EQUIPMENT PKG. Z88 - GMC TRUCK NAMEPLATE 1SZ - POWER PACK SAVINGS 16U - STEEL GRAY METALLIC 4SA - SLT DECOR INCLUDES: *PWR FRT/PASS 10-WAY SEAT ADJUSTER *ELECTROCHROMIC ISRV MIRROR WITH COMPASS & TEMP *ELECTRIC REAR WINDOW DEFOGGER *DEEP TINTED GLASS *AM/FM STEREO W/6-DISC CD PLAYER *BOSE PREMIUM SPEAKER SYSTEM *REAR AUDIO CONTROLS *CRUISE CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY SYSTEM *OSRV MIRRORS W/PWR FOLD & ADJ, HEAT & TURN SIGNAL; ELECTRO- CHROMIC DR-SIDE MIRROR *LEATHER-WRAPPED STEERING WHEEL *FRONT FOG LAMPS *CHROME GRILLE *BODYSIDE MOLDINGS *ALUMINUM WHEELS *AUTOTRAC TRANSFER CASE 6YT - COMPONENT FRT LH COMPUTER SEL SUSP 69I - DARK PEWTER INTERIOR TRIM 692 - DARK PEWTER LEATHER 7YT - COMPONENT FRT RH COMPUTER SEL © 1998-2005 General Motors Corporation. All Rights Reserved. GM Vehicle Inquiry System Claim History VIN : 2GTEK13T561159752 CLAIM HISTORY Repair Order Date : 10/28/2005 Repair Order Number : 186276 Odometer Reading : 6 miles Serviced By : STAR PONTIAC BUICK GMC 260 COUNTRY CLUB RD EASTON, PA 18045-2341 (610) 258-3800 Selling Source : 48 - GMC TRUCK Site Code : 06019 Business Associate Code : 115618 Cycle Date Cycle Nbr Case Type Labor Operation Part Comments 11/04/2005 636 01 I Z6998 - PDI ADDS N/A Y Repair Order Date : 09/12/2005 Repair Order Number : A59752 Odometer Reading : 0 miles Serviced By : STAR PONTIAC BUICK GMC 260 COUNTRY CLUB RD EASTON, PA 18045-2341 (610) 258-3800 Selling Source : 48 - GMC TRUCK Site Code : 06019 Business Associate Code : 115618 Cycle Date Cycle Nbr Case Type Labor Operation Part Comments 09/16/2005 622 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N © 1998-2005 General Motors Corporation. All Rights Reserved. GM Vehicle Inquiry System Delivery Information VIN : 2GTEK13T561159752 IN-SERVICE INFORMATION In-Service Information Not On file DELIVERY INFORMATION Delivery Date : 01/23/2006 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 35 miles Delivering Dealer : STAR PONTIAC BUICK GMC 260 COUNTRY CLUB RD EASTON , PA 18045-2341 (610) 258-3800 Delivery Selling Source : 48 - GMC TRUCK Delivery Site Code : 06019 Business Associate Code : 115618 © 1998-2005 General Motors Corporation. All Rights Reserved.
MS3DALE Posted January 31, 2008 Posted January 31, 2008 New to forum, would you mind running mine 1gcek19y27z575561Thanks a lot. I just bought the truck and cannot wait to get it. GM Vehicle Inquiry System Vehicle Build VIN 1GCEK19Y27Z575561 VEHICLE BUILD Merchandising Model : CK10553 -2007 SILVERADO 1500 4WD EXT CAB LTZ Gross Vehicle Weight Rating : 3087 kg (6807 lb) Order Number : KTFV57 Build Date : 03/13/2007 Build Plant : 17Z53 GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. OPTION CODES ABV - POWER REAR SIDE WINDOW AG1 - POWER DRIVER SEAT AG2 - 10-WAY POWER PASSENGER SEAT AJ1 - DEEP TINTED GLASS AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS AN3 - FULL FEATURE BUCKET SEATS AP3 - REMOTE START AU3 - POWER DOOR LOCK SYSTEM AXN - AXLE, HYBRID A31 - POWER WINDOWS A68 - SEAT, 60/40 REAR FOLDING BENCH B30 - CARPETING, COLOR-KEYED B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS B85 - BODY SIDE MOLDING CF5 - ELECTRIC SLIDING SUNROOF CJ2 - DUAL-ZONE AUTO AIR CONDITIONING C49 - ELECTRIC REAR WINDOW DEFOGGER C5U - GVW RATING - 6,800 LBS DF5 - ISRV MIRROR W/COMPASS & TEMP DH6 - LIGHTED VISOR/VANITY MIRRORS DK8 - DELUXE OVERHEAD CONSOLE DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL (REPLACES STD/PKG MIRROR) D07 - CUSTOM FRONT FLOOR CONSOLE E63 - FLEETSIDE BODY FWI - FORT WAYNE PLANT GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING REAR DIFFERENTIAL JF3 - 17" BRAKES, DISC/DRUM KC4 - ENGINE OIL COOLING SYSTEM KG3 - 145 AMP ALTERNATOR KNP - HD AUX TRANS. COOLING SYSTEM K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER L76 - VORTEC 6.0L V8 SFI GAS ENGINE W/ ACTIVE FUEL MGT TECHNOLOGY M70 - TRANSMISSION, 4-SPD SUPER DUTY NC7 - FEDERAL OVERRIDE NE1 - 50-STATE EMISSIONS NP5 - LEATHER WRAPPED STEERING WHEEL NQH - TRANSFER CASE NU5 - EMISSION CALIFORNIA BIN 4 NZZ - OFF ROAD - SKID PLATES NZ4 - FULL SIZE 17" STEEL SPARE WHEEL N87 - 18" ALUMINUM WHEEL (REPLACES STD/OPT WHEEL) QXQ - P265/65R18 WOL OOR TIRES R6K R6P - PREMIUM PAINT R9K - WHOLESALE FLOOR PLAN PLUS R9N - PROCESSING OPTION ONLY LEATHER SEAT TRIM R9Z - POMS EXPEDITE-SOLD ORDERS/TSE SAF - SPARE TIRE LOCK SLM - STOCK ORDERS SLT - EQUIP CHEV 'LT' SALES PKG T74 - HEADLAMPS T96 - FOG LAMPS UE1 - ONSTAR SERVICE: INCLUDES 1 YEAR SAFE & SOUND PLAN UG1 - UNIVERSAL HOME REMOTE UJ6 - TIRE PRESSURE MONITOR UK3 - STEERING WHEEL RADIO CONTROLS UQA - BOSE PREMIUM SPEAKER SYSTEM US9 - AM/FM STEREO W/MP3 COMPATIBLE 6-DISC CD CHANGER (REPLACES STD/OPT RADIO) VB3 - CHROME REAR BUMPER VG3 - CHROME FRONT BUMPER VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL V22 - CHROME GRILLE V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA V76 - RECOVERY HOOKS XA7 - HEATED WASHER FLUID SYSTEM X88 - CHEVROLET CONVERSION YD3 - BASE AXLE YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING YE9 - SILVERADO ZK3 - PULL AHEAD DESIGN ZRS - P265/70R17 SPARE TIRE ZY1 - SOLID PAINT Z71 - Z71 EQUIPMENT PACKAGE Z82 - HD TRAILERING EQUIPMENT 1LZ - SILVERADO LTZ EQUIPMENT GROUP: * 12 WAY POWER HEATED BUCKET SEATS W/DRIVER MEMORY * FRONT LEATHER SEATING SURFACE * OSRV MIRRORS W/POWER FOLD & ADJ, HEAT, TILT, TURN SIGNAL AND DRIVER SIDE AUTO DIMMING * BOSE PREMIUM SPEAKER SYSTEM * UNIVERSAL HOME REMOTE * HEATED WASHER FLUID SYSTEM * REMOTE VEHICLE START * HD TRAILERING EQUIPMENT * LOCKING REAR DIFFERENTIAL * POWER LOCKS AND WINDOWS * INSIDE REARVIEW MIRROR, AUTO DIMMING, COMPASS, TEMPERATURE * REAR ACCESS DOOR PWR WINDOWS * REMOTE KEYLESS ENTRY * AUTOTRAC TRANSFER CASE 1SZ - OPTION PKG DISCOUNT 19I - EBONY INTERIOR TRIM 193 - EBONY LEATHER 41U - BLACK 6HZ - SUSPENSION 7HZ - SUSPENSION © 1998-2005 General Motors Corporation. All Rights Reserved. GM Vehicle Inquiry System Claim History VIN : 1GCEK19Y27Z575561 CLAIM HISTORY Repair Order Date : 10/15/2007 Repair Order Number : 037261 Odometer Reading : 3292 miles Serviced By : BLAKE CHEVROLET PO BOX 369 NORTH HAMPTON, NH 03862-0369 (603) 964-2990 Selling Source : 13 - CHEVROLET Site Code : 32053 Business Associate Code : 187878 Cycle Date Cycle Nbr Case Type Labor Operation Part Comments 11/09/2007 846 01 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT N/A N 10/30/2007 843 01 # J1000 - PAN AND/OR GASKET, OIL - REPLACE 15203889 - GASKET Y Repair Order Date : 03/13/2007 Repair Order Number : A75561 Odometer Reading : 0 miles Serviced By : BLAKE CHEVROLET PO BOX 369 NORTH HAMPTON, NH 03862-0369 (603) 964-2990 Selling Source : 13 - CHEVROLET Site Code : 32053 Business Associate Code : 187878 Cycle Date Cycle Nbr Case Type Labor Operation Part Comments 03/16/2007 778 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N © 1998-2005 General Motors Corporation. All Rights Reserved. GM Vehicle Inquiry System Delivery Information VIN : 1GCEK19Y27Z575561 IN-SERVICE INFORMATION In-Service Information Not On file DELIVERY INFORMATION Delivery Date : 06/12/2007 Delivery Type : 015 - RETAIL LEASE/INDIVIDUAL Delivered Odometer : 32 miles Delivering Dealer : BLAKE CHEVROLET PO BOX 369 NORTH HAMPTON , NH 03862-0369 (603) 964-2990 Delivery Selling Source : 13 - CHEVROLET Delivery Site Code : 32053 Business Associate Code : 187878 © 1998-2005 General Motors Corporation. All Rights Reserved.
cdcrum Posted February 1, 2008 Posted February 1, 2008 Is there somewhere we can go ourseleves to do a VIN search? Thanks, Chris
