Front Faschia (sp?)
OMG the black part underneath the bumper on my truck makes my front end look SOOO LOW
i think it's called front faschia..anyways..does anyone ahve any pictures of their truck without it?!
i would go and just remove it....but i have a broken foot and it's cold as f**k out
The lower part comes off pretty easily. A few in here have done it and like the look.
You should NEVER break your foot.
I've always called it the lower valance. Lots of guys have removed it, and it does look a lot better.
Not my trucks, but some w/ out the valance.
I think I like the look without the lower valence. Cold here also, so might just wait till spring and strip it down. Already removing the badges but just a few at a time. Makes it like I get a new truck every few months or so! :)
Hope the foot heals well.
yeah breaking feet sucks
well i didnt' break it, but i dislocated and fractured some bones and apparently 'ground bones together creating a fine powder' out of a bone or some s**t..surgery and alll that s**t...f**kin sucks
i'll remove the valance this spring!!
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
