Engine Hour Meter
damoperator
I have a 2006 2500WT with 6.0L 4x4 auto. When I filled the truck up last night and reset my mileage, I noticed that the engine hour meter was reset or rolled to 1.4 hours. The truck odometer is 51849. No work has been done on the truck, no accessories added, nothing added or nothing noticeably wrong. ???
I have seen similar stuff. Some say the hours are like miles and should not reset.
Dealer gave me a line of BS that I did not beleive.
I had the same thing happen on my burb. I held down the enter key on the steering wheel and the total engine hours was reset. I haven't been able to get it to repeat again, and the dealership said not possible. I also reset my engine oil life thing by the same method and I dont think thats supposed to happen either. I want to know my real engine hours dangit.
thought I would pass along some info.found a bulletin for this problem.IPC Engine Hour Meter Resets - keywords cluster DIC display hour meter intermittent start up #PIT4368A - (05/29/2007)2003-2007 Chevrolet Silverado Classic
2003-2007 GMC Sierra ClassicSome owners may comment of the ipc engine hour meter resetting. This concern may be very intermittent and normally occurs at key up and/or start up.
GM Engineering is aware of this concern and working on a correction. At this time there has been varying success repairing this concern with the following information:
  1. <LI type=1>Check the battery/s with the Midtronic's battery tester and also perform a load test using a Vat40 or similar load tester to make sure the battery/s are in good condition. We have found in some cases a weak battery could cause this concern, this step is very important on vehicles with the 6.6L Diesel Engine where both batteries are used for cranking the engine. <LI type=1>Check the battery cables and make sure all connections are clean and tight. <LI type=1>Check the IPC powers and grounds (G200, G203, G100, G110 and the braided ground strap between the engine and cowl G104 and G107) connections and make sure they are clean and tight.
  2. If the IPC has not been replaced, replace the IPC.
of course you can reset the oil life monitor, & what brian said
Hey guys, I called my local dealer today and he said that he has never herd of this happening. He did ask me was the hours adding up from the unexplained reset and I said sure. He also said that since it was counting now not to worry about it. But what about my total engine hours?
exactly my thoughts. I also got curious and called the dealer and they said the same thing, never heard of it. The TSB makes it sound like an intermittent thing, but it is not on mine it started back to zero. I also tried to reset it again just for grins and no can do on the life hour meter. I wonder if they can pull it off. I wouldn't think the data would be saved in the actual display/IPC but could be wrong.
Also, is the oil life meter supposed to reset when you hold down the enter key? I thought you had to go through the whole key and accelerator sequence?
Thanks, Jared
  • 1 year later...
Thanks, Jared
I have noticed since mine reset about 2 weeks ago that I did not get my low fuel warning notice on the read-out screen, nor low washerfluid notice.
I'll be danged if I am going to spend to have the cluster replaced.
I would check to see if there are any recalls for your specific year and model on the IPC. I have a 2004 2500HD and there is a campaign # 07187B (for 2003 - 2004) that actually extends the warranty on the IPC due to numerous problems. This basically houses a computer and when I had mine replaced it required programming of the VIN, mileage, & hours. In this case the warranty is only extended to 70K miles. Good Luck.
  • 2 months later...
All 2003-2004 Chevy Silverado Instument Panel Clusters are now covered for 7 years, 70K miles. I just had mine replaced today at no cost for a faulty oil pressure guage. HOWEVER, the new cluster reads 3000 engine hours when the old cluster was at 912. They told me to forget it or else they would have to order another IPC. It only took 24 hours for the part to arrive and 25 minutes for the change out. No muss, no fuss.
Is your mileage correct? That's all I'd be concerned about.
    MANGOAL
    MANGOAL
  • Who's Online   6 Members, 0 Anonymous, 545 Guests (See full list)
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
