JOKE
General Lee 01
Alright the criminal part doesn't matter much.
Let me lenghin it out for yall.
The blonde was @ a restaraunt (The sit down, get waited on type) and she was in a hurry so when it came time to pay she gave them her credit card and said "Keep the change" and left.
Get it yet?????
wow i must be cause i didnt get it the first time
Oh, I got it the first time, but it is kind of like the guy that tries to tell a joke like:
"a man walks up to me and asks me 'which direction is it to Carnegie hall?',  so I said lots of Practice"
The setup just does not work with the punchline.
Sorry, I just can't resist the easy attacks  :)
(Edited by patrick at 11:47 am on Aug. 14, 2001)
(Edited by patrick at 1:19 pm on Aug. 14, 2001)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
