Tech2 Features
kollteh
Hello, I have got a question.
Being a overseas GM user, I face poor GM dealers professionalism, which means that they do not actually know how to handle with tech2 kit and can't explain what it can do and what it can't.
My question is following:
if I buy tech2 kit with all +kits and software, will I be able to reprogram my truck in the way I want, or I will be somehow restricted due to dealers issues (I mean some passwords or any other stuff)? And if I will be able to use Tech2 as i need to, will it be possible to reprogram multimedia systems of the truck?
Thanks, Nick
ps: if Tech2 is not appropriate for car multimedia reprogramming, what can anyone suggest for this purpose?
we go thru GM infonet which is password protected,so no,tech 2s cost $3000 plus the candi module for the newer veh's,our service information is also web based,though you can purchase that,thanks for playing,
You can get the Tech2 and get the software updates from gm, but you can do your own personal ajustments
use this link it will explain all the operations of the Tech2
http://service.gm.com/userguides/english/t2ug-en.pdf
Your best bet for the money is the OTC Genisys. With the software packages you can use it on all make out there and plus you can get the software to do the gm programing just like the Tech2
http://www.genisysotc.com/
If you want to do your own personal programing to the pcm use JET Dynamic Spectrum Tuner
http://www.jegs.com/p/JET/762010/10002/-1/10373
Thank you!
I appreciate your information.
However, I still do not understand if any of these devices will let me work with the car multimedia system.
Is any?
