Autodim Mirror Wiring ?
Ok, so I've got a OEM Autodim mirror for my 07 and I'm in the process of installing. Upon inspection, i noticed there are 11 wires, compared to the 4-5 on my original mirror.. So my question is, where's the best place to find out the COLOR CODES for these wires, or where they are run. I did hook up the mirror, and the onstar did work, however the compass didnt as well as the temp. I know atleast 1-2 of the wires will be for the temp sensor, but what about the other million wires? From what i understand the compass is powered by the mirror itself, so the only "extra" wires there should be is for the temp sensor.. I've googled untill I'm tired.. Any info on the color codes would be greatly appreciative. Thanks
Don't know if this will help, but I just pulled out the entire wire harness of an 05 today and installed the temp and compass mirror on an 02 that did not have it. The sensor wire colors for that year are the green/white stripe, black/white stripe. The positive was yellow and ground black was all I needed and it worked. You could figure it out by looking at a buddy's truck and tracing wires
d**n. I just came across the ENTIRE Wiring Schematics for 07-08 NBS truck. And I also found the wire code for the mirror. Turns out the power wire is pink no yellow..
where did u find that, i could use that as well
    Selfman
    Selfman
  • Who's Online   5 Members, 0 Anonymous, 888 Guests (See full list)
