Need A Part Number
ScottyBoy
I need a blend door actuator for a 2001 Suburban with the rear climate controls. Is there a different part number for trucks with rear climate controls? I need the correct part number for my truck My VIN IS : 3GNEC16TX1G181018 if its needed to get the correct part number for me. Also, I might as well change the cabin air filter while I'm under the dash, so I'll need the part number for that as well. THANKS
anybody?
Pretty technical. Might have to get your dealer parts guy involved.
Considered a local boneyard? I bet a ton of money could be saved on an item that rarely dies. Just a thought.
But thats just it, this part doesnt "rarely die". From what I've resaerched on here, it seems this actuator goes out quite often. Some members on here have had it go out several times. I even found a part number on here and found out that it less than 50 bucks. But the part number I found was for a 99-02 sierra/silverado. I'm just trying to find out if its the same for SUV's with the rear climate controls. I know some AC parts are different, just trying to see if this is one of them.
AND just to make sure the correct part I'm speaking of, it's the actuator just behind the center console in the very bottom of the dash, just above the transmission hump. Not the actuator way up inside the dash. This actuator just controls the temp (from hot to cold) , not change the airflow to the defoster, etc.
Send www.gmpartsdirect.com an email w/ your VIN and what you are looking for and within a couple of days they'll send you the part number.
Thank you, John. By the way, your post on relacing your actuator was very informative. Good description calling it a "baby grand piano". I found several other post that instruct you to NOT plug the harness back in until you get the actualor completly mounted. That will get it out of alignment and maybe even cause it to fail. That me be why several people have had to replace it more than once.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
