Truck Jumping At Stops
crank74
My 2007 NBS Silverado is jumping at stops. It almost feels like I am getting rear ended. I don't feel any funny stuff going on with the brake pedal. I heard it might be the drive shaft yoke getting bound up and then slipping back into place. Any help would be appreciated. :)
Yup.... slip yoke bind, 2 piece shaft you can pop it apart and grease it up, 1 piece need to pull shaft
Either way use brake clean and clean out whatever is inside slip joint, then use the GM "blue" grease
2 piece shaft you can always drill and install a zerk into slip joint housing
edit: I figured they'd have fixed this by now... guess not
I just greased mine and it seems to have solved the problem. However, was told that it may come back in time and need to be greased again. Not a big deal though. 4 bolts and it slides right out.
Anon
