Biggest Tires Possible?
Hey there i had my truck recently lifted so im able to now put on A LOT bigger tires.
My question is; if i keep my old rims what are the biggest possible tires that i can put on those rims??
The tires that are on the rims right now are 265x75x16.
Is it possible to fit like 35's onto those rims or will they look retarded because teh rims are not wide enough. Not sure what to do!
Thanks in advance for your advice!
OHHH and i dont care if they rub a little bit i want big as possible that i can. so dont worry about that kind of stuff :thumbs:
Ryan
Ryan
Give the search function a whirl. Tire and wheel discussions have been covered again and again here. If you can't find anything right away, try the advanced search, it often provides much better info.
Daddy
How wide are your rims now? If its the rims on the truck in your sig they look like 8" wide rims. With that being if there 8" rims then a 35x12.50x16 will fit on a 8" rim but your going to have to lift the truck to fit them under the wheel wells. Now if the rims are less then 8" they will fit but the center of the tire will be rounded due to the rim pulling the sidewalls on the tire in too much. If your not going to lift the truck then a 285 is about as big as you can go without rubbing but you may get some.
    250.3k
    NN16HD
    NN16HD
  • Who's Online   1 Member, 0 Anonymous, 428 Guests (See full list)
