05 Bose Cd Changer Issue
Hi All,
I need some assistance from some more knowledgable people. At the beginning of January I had a stereo shop add an auxilary input adapter to the back of my stereo so I could hook up a mp3 player through a 3.5mm jack. It instantly didn't work, with the cd changer function suddenly not being recognized. The cd icon would flash on the stereo display. It did show that it had CDs in the changer but couldn't eject them either. They kept fiddling with it trying to make it all work and when it did, it only worked for an hour or so. They found out later that it wouldn't work because the part wouldnt work with my stock Bose with built-in 6 disc changer (opposed to single disk). They were going to order the "right" part but I gave up on them and had them pull everthing, it all seemed to be working again before I had them touch it. I wish I knew the exact brand/product they were using, but I can't remember anymore.
The stereo went back to working normally, radio, xm, cds, but after a few days the cd changer quit working (could still listen to FM/AM/XM thankfully). Sometimes it'd come back later in the day, sometimes it'd take a day or two for the cd function to work again. When it isn't working, you can press the cd eject button and an "Initializing..." message comes up on the display, but nothing else will happen. I have started to get into the dash myself now and saw that they stripped the wire (pinkish red on top left of connector) they needed to use and had soldered in a connecting wire I assume was needed for the auxilary adapter. I cut off the extra wire and retaped everything back up. I plugged the stereo back in and it automatically reset the cd changer and everything works again. Next day... the cd icon is flashing again and the cds can't be played. If I unhook the stereo and hook it back in while the truck is powered, it'll go back to working normally, but I can easily assume that it'll go bad again and quit working.
My big question to the stereo experts is... do you think its having issues because of the solder still on the wire and being spliced into, or do you think in some way it has caused damage to the internal electrical components of my stereo?
I'm looking just to get it all working again (don't want to invest more money into all this), it is really starting to drive me nuts. I can take pictures if anyone wants to see what any of this looks like as well. Thanks for the help.
For extra information:
2005 Chevy Silverado Ext. Cab Std Bed. Z71
LT model w/ indash 6-disc Bose stereo & XM radio
    • The part # is 84520447, mine does not have the cooled seats but I'm willing to possibly change the cover and foam if needed.   I tried that site and a few others,  added to cart and then paid. About an hout later I received a refund stating it has been discontinued.
    • Thought I would add to what Bruce answered, not only do the HD models use the torsion bar system, there are I believe 5 different torsion bar spring ratings that are all physically interchangeable with all the HD trucks going from a two wheel drive 2500 all the way up to the duramax or a gas engine truck with a snow plow prep package front end weight capacity that use the maximum sized torsion bar. It starts from a 4400 lb rated set in 400 lb increments up to 6000 lb. If one wants to fine tune the ride for a certain truck application they can swap out the torsion bars.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
