Dash Removal
remove the front a pillars (driver side requires a 7mm socket behind the little clip, passenger side requires removal of 2 10mm bolts inside the grab handle, then slide them out, making sure to unclip the factory tweeter harness on each side). then slide your finger undernieth the front pannel and pop it up. there are 7 or 8 clips that latch it in place. pull straight up and they will pop off. then unscrew the light sensor by turning counterclockwise, i believe. there you go, takes all of 5 minutes
