  • Replies 391
Top Posters In This Topic
leave pun alone :lol:
Eat my shorts, cotton muncher :lol::thumbs::thumbs:
ok chowder chugger :lol:
Is that the best you can do, kid. You ain't even man enough to piss me off.
Don
Post #3000...with 3 days to spare!!!! WOOOHOOO!!!!
Count'em....FIVE wrenches bitches!!!!
Now, where do I go to get a life again? :lol:
Nice job reaching 3000. I see it didn't take you long to get you a shirt made.
Don
not worth my time red neck cracker
Don
So what exactly is worth your time?
Eat my shorts, cotton muncher :thumbs::thumbs::lol:
Don
How's 10th grade Dave? Still pullin' straight A's? :lol:
Wow, the camera sure does make me look fat. :lol:
Edited by VMax2007
Don
What is trolling, Alex? :lol:
tailrider is just a kid and not sure of his sexual orientation yet???
I see...does he even own these vehicles he displays in his glorious sig and personal info?
Really, I was thinking, in fact, that you made that shirt look fat. :thumbs:
Edited by daddy
Hey Pun,
Trade in your ticking POS Silvy for a Tundra yet? Maybe you and Trailrider could hang out....if Trailrider's dad let's him borrow his Tundra that is?
I have an extra silly string rifle if anyone wants to play :lol::lol::D
SAY HELLO TO MY LITTLE FRIEND.....
THE NEW SILLY STRING CANNON!
:lol::thumbs: Hose emm down...they are outta control!!! :thumbs::lol:
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,134 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
