Transmission Noise On My 08 Gmc
Ok maby someone can help me out here. I just bought a 2008 GMC Sierra 1500 SLE2 NFL package. When the truck shifts from 2nd to 3rd it almost sounds like and feels like a ZIP noise under my feet. This noise and feeling is easier to feel when shifting at slower speeds in my neighborhood, but it only happens from 2nd to 3rd gear, it doesnt jerk or feel like it is slipping and the other gears shift fine. It is very hard to hear from the passenger side unless you know what to listen for and when. This is not the clunk noise that most GM and Chevy owners hear from the transmission. The truck has 610 Miles on it. Any input would be helpful. Thanks
To be honest I thought I was just hearing things also. I first heard that sound with around 100 miles on it. It now has 450 miles, still kind of makes the same noise at the same low speeds from 2nd to 3rd. I'm taking the truck to the dealer in the morning for them to fix the oil leak that I found this morning and will tell them about it then.
Maybe this is the noise I am hearing too, I had a really hard time describing how it sounded. Dealer is going to check it out on Wednesday, along with a few other things
The best I could describe the sound would be the sound of fluid transferring around in the transmission. To me I don't think I should be hearing any noise coming from the transmission. Maybe this is a new feature of the 08'. :crackup:
Thats also what it sounds like only from 2nd to 3rd
If that's the same noise, it's been happening before the nbs. I've heard GM trucks, including mine on up to 2006 making that noise on shifts. Weird sound.
After going to the dealer this morning for an oil leak with 500 miles on the truck, let me tell you how funny it is that I was not able to reproduce the sound for the lead tech on a test drive. Even after describing all symptoms above they said they've never had any reports for this. So I was basically told to record any and all condtions of and or around the truck the next time it makes the sound. I'm sure it will be back in the shop within a month to refix the oil leak they just fixed. Until then I almost want to keep a sound recorder in the truck cause I know I'll hear it with no one elese around. :lol:
What did they do to try to fix your oil leak?
They had me in and out in 3.5 hrs after changing the oil pan gasket. After seeing the other post on oil leaks, I'll be keeping an eye on this over the next week. 1 dop and its going right back. They at least told me after words "This won't count as your 1 free oil change". I said thanks and just walked out shaking my head.
Yep, you'll be going back, mark my words. It was NOT your oil pan leaking. Tell them it's the CPS o-ring, rear main and/or the oil cooler line manifold gasket (only if you have the 6.0, otherwise you don't have oil cooler lines).
The tech did mention the rear main and also the galley plug, which i am unfamiliar with. After it went back they were pretty quick to come back and say it was the pan.
So i guess I can assume this is a normal unexplained noise in the transmission, since it seems like others can hear the same sound or some type of noise from when shifting from 2nd to 3rd??
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
