Slight Transmission Slip
yeehaw87
I have a 96 silverado 350 with the 4L60E tranny. Lately it has had a slight slip from one to two. I was told it could be the valve body by a friend, which is a common problem, but I dont want to go buy a part that costs 400 bucks on just a hunch. I changed fluid and it seems to shift better. Is this a common problem when the valve body goes out? Also, my check engine light has a tranmission code on it now too, but it only says trans. system malfunction. Thanks for your help.
