Wanted
I NEED A 4L80E TRANSMISSION FOR MY 1996 SIERRA K2500HD 4X4 350. THEY ARE VERY HARD TO COME BY. IF ANYONE HAS ANY INFO ON WHERE I CAN GET ONE USED AND IN GOOD SHAPE. THANKS.
