Ford Tuned ?
I am trying to find some where to get my dads Ford custom tuned any ideas?? Thanks
Huh? Did you say something??? :D
Haha, he posted that pic to distract us and thought we'd read that wrong!
Any way, any where that does tuning can do it. Nelson, Black Bear, W4M, or he can get a Diablo and they will make a custom tune for the handheld.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
