Wheel Question
Do you know what wheels are on the tahoe in that show "Rob and Big" on MTV?
His Tahoe is "murdered out" (flat black paint) and has flat black wheels. I think they were either a 5 or 6 spoke design.
Does anyone know where I can get them?
I know he had them custom painted or powder coated that way but I can't remember the brand.
You can google it and there should be an article from a magazine that describes it. I believe it was rides magazine that did a feature on his Tahoe and Big Blacks "murdered out" pinto.
