Gm 2500hd Best Offroad Options..advice!
I just sold my F-150 and planning to buy 2008-2009 GM Sierra 2500HD with best options for offroad!
Need your advice on the options for offroad mostly driving on sand which require a tough car!, also I am looking for extended cap with short bed, which I can't find like in the Ford?..
4 wheel drive
G80 Locker, aggressive off road tires, a lighter gas engine is often a benefit off-road, but it depends on what you'll be doing with it. Normally a 3/4 ton truck is not best suited for off-road use since it's suspension is so firm. But if by off-road you mean dirt roads, then that's not so much an issue.
DEWFPO
Just order the Z71 package,It will give you the "G80" locking differential and the "NZZ" skid-plate package,along with 46mm shocks,off-road jounce bumpers,and a 36mm front stabilizer bar all in one package.
The Z71 package also requires that you order either the LT245/75R16"E" on/offroad tires or the LT265/70R17"E" all-terrain tires.
Wider tires are better in sand, skinny ones are better in the muck.
All good replies, many thanks. Z71 is the key word here and 4x4.
but does this include the tempreture control features like the oil coolers, engine coolers ...
but does this include the temperature control features like the oil coolers, engine coolers ...
Yes,Engine oil & an auxiliary transmission oil cooler are standard with the 6-liter engine.
    ar0517
    ar0517
  • Who's Online   6 Members, 0 Anonymous, 700 Guests (See full list)
