Air Conditioning
ames43
I have an 03 Yukon Denali. My ac works great one minute then the next it's not working? Any ideas? I have the 6.0 engine and I have 71000 miles on it in great shape. :banghead:
I second the Low Pressure cycling switch, my 04 did the same thing so I took it to the dealer to have it checked and the service manager came out with a new one and changed it in the service lane, he just unhooked it uncrewed it and put the new one on. He said they had alot of these come back for this problem and that Chevy had gotten alot of bad ones from the manufacturer .
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
