Cargo Management & Bed Liners
I have a 2007 NBS Crew Cab and I Have the cargo Management System with the tool box
Options..
1. Spray Line-x
2. Dual Liner http://dualliner.com/ (would have to cut it to make it work)
3. Drop in Liner
My problem is how do you remove the Cargo Management system &
Will the tool Box still slide?
anyone do any of these? post pics of you have....
I don't have any pics, but I have the factory liner with CMS, both installed prior to delivery of the truck. I think the liner could be ordered with and without CMS, so the cutouts you need should be factory made.
That dual liner looks like a good idea. If I didn't already have my Line-X I'd consider getting the dual pretty seriously.
You will need to get a liner that has the cut outs for the cargo management system. GM has one that has the cut outs. If you do the line X, you will simply have to remove the tool box, and CMS (remove a few bolts), and make sure they don't line x those bolt holes.
-Al
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
