Vin Check Please
Would someone be so kind as to get me a VIN check on my truck?
Thanks in advance.
1GDJK34D47E11513
Your missing a digit,You need 17,You only have 16 listed.
Thanks in advance.
1GDJK34D47E11513
Thank you here is the corrected VIN
1GDJK34D47E111513
Here you go:
1GDJK34D47E111513
GM Vehicle Inquiry System
Summary
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN : 1GDJK34D47E111513
VEHICLE INFORMATION
Merchandising Model : TK36003 -2007 SIERRA 3500 4WD REG CHASSIS W/T Warranty Start Date : 12/28/2006
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MATHENY MOTOR TRUCK COMPANY
PO BOX 1304
PARKERSBURG , WV 26102-1304
(304) 485-4418
Selling Source : 48 - GMC TRUCK
Site Code : 50593
Business Associate Code : 119540
Service Contract :
No
Branded Title :
No
Warranty Block :
No
PDI Status :
Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description
Effective Date
Effective Odometer
End Date
End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY
12/28/2006
25 miles
12/28/2009
36025 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY
12/28/2006
25 miles
12/28/2012
100025 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM
12/28/2006
25 miles
12/28/2014
80025 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY
12/28/2006
25 miles
12/28/2011
100025 miles
60/50000 FEDERAL EMISSION
12/28/2006
25 miles
12/28/2011
50025 miles
60/100000 GM DIESEL ENGINE IN LIGHT DUTY VEHICLE LIMITED WARRANTY
12/28/2006
25 miles
12/28/2011
100025 miles
CLAIM HISTORY
R.O Date
R.O Number
Type
Labor Operation
Odometer Reading
01/05/2007
047414
J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 246 miles
01/02/2007
047219
F1671 - SEAL, HUB OIL - REAR AXLE - LEFT - REPLACE 166 miles
01/02/2007
047219
D
08/28/2006
A11513
I
Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
? 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
Help
CLAIM HISTORY
Repair Order Date : 01/05/2007 Repair Order Number : 047414 Odometer Reading : 246 miles
Serviced By : MATHENY MOTOR TRUCK COMPANY
PO BOX 1304
PARKERSBURG, WV 26102-1304
(304) 485-4418 Selling Source : 48 - GMC TRUCK
Site Code : 50593
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
01/19/2007 762 01 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS N/A N
Repair Order Date : 01/02/2007 Repair Order Number : 047219 Odometer Reading : 166 miles
PO BOX 1304
Site Code : 50593
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
01/30/2007 765 01 D F1671 - SEAL, HUB OIL - REAR AXLE - LEFT - REPLACE N/A N
01/19/2007 762 01 # F1671 - SEAL, HUB OIL - REAR AXLE - LEFT - REPLACE 15007008 - SEAL-RAXL N
Repair Order Date : 08/28/2006 Repair Order Number : A11513 Odometer Reading : 0 miles
PO BOX 1304
Site Code : 50593
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
09/01/2006 722 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
Help
VIN 1GDJK34D47E111513
VEHICLE BUILD
Gross Vehicle Weight Rating : 5448 kg (12013 lb) Order Number : KCCVX6
Build Date : 07/21/2006 Build Plant : 17E03
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - UPLEVEL 40/20/40 FRT SPLIT BENCH SEATS - CUSTOM CLOTH B3P - BAILMENT COMMERCIAL ORDERS
B71 - WHEEL FLARES CJ3 - DUAL ZONE AIR COND - MANUAL
C7L - GVW RATING - 12,000 LBS DG5 - WEST COAST TYPE EXTERIOR MIRROR
FE9 - FEDERAL EMISSIONS FNF - FLOOR POWER TAKE OFF
FT2 - ARM TORS BAR SPRING ADJ FT3 - ARM TORS BAR SPRING ADJ
F60 - HEAVY DUTY FRONT SPRINGS GMC - ASSEMBLY PLANT-PONTIAC EAST
GT4 - REAR AXLE, 3.73 RATIO G80 - H.D. RR AUTO LOCK DIFFERENTIAL
HVY - IDEN 2 INCH BODY RAISE,HD MODEL JH7 - 4 WHL PWR DISC BRAKES,12000 LBS
KC4 - ENGINE OIL COOLING SYSTEM KG3 - ALTERNATOR 145 AMP
KNP - H.D. TRANSMISSION OIL COOLER KUP - THROTTLE CONTROL ELECTRONIC
K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER LBZ - DURAMAX 6.6L V8 TURBO DIESEL ENG - 360HP, 650LB-FT TORQUE
MW7 - ALLISON 1000 6-SPEED AUTO TRANS M1F - POWER TAKE OFF ACCESS
NP2 - MANUAL SHIFT TRANSFER CASE NT9 - EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT
NZZ - OFF-ROAD SKID PLATE PKG PDN - HEAVY DUTY POWER PACKAGE INCL: *DURAMAX 6.6L TURBO DIESEL ENG-360HP, 650 LB-FT TORQUE *ALLISON 1000 6-SPD AUTO TRANS *H.D. RR AUTO LOCKING DIFF
PDP - FULL-FLOOR RUBBER COVERING PTO - PROVISIONS FOR POWER TAKE OFF
R4Z - GENERAL TIRE BRAND R6K
R6P - PRICE LABEL PAINT CHARGE R6V - UPFIT IDENTIFIER
R8A - LAM PROCESSING EXEMPTIONS R8C - ******************************* ***** 2007 CLASSIC SIERRA ***** *******************************
R9N - LEATHER SEAT TRIM R9Z - POMS EXPEDITE-SOLD ORDERS
SLM - STOCK ORDERS TQ3 - BATTERY 770 CCA (DUAL)
TRW - PROVISIONS-ROOF MOUNTED LAMP TS9 - CENTER HIGH MOUNTED STOP LAMP AND CARGO AREA LAMPS, DELETE
UM7 - AM/FM STEREO (REPLACES STD/OPT RADIO) UQ5 - STANDARD SPEAKER SYSTEM
U01 - ROOF MARKER LAMPS VC0 - LABEL NOISE CONTROL INFORMATION
VF7 - DELETE REAR STEP BUMPER VGH - SHIP THRU - MONROE MOD CEN
VG3 - CHROME FRONT BUMPER VK3 - FRONT LICENSE PLATE MOUNT
VXT - INCOMPLETE VEHICLE VYU - SNOW PLOW PREP PKG INCLUDES: *INCREASED CAPACITY SPRINGS *ROOF LAMP PROVISIONS *145 AMP ALTERNATOR *SKID PLATES
V10 - WINTER COVER V73 - STATEMENT OF CERT. U.S.
XEF - LT215/85R16/E OOR BW TIRES YD3 - BASE EQUIP FOR SCH GVW PLATE
YD5 - FRONT SPRING - BASE EQUIPMENT YD6 - REAR SPRING - BASE EQUIPMENT
YEF - LT215/85R16E BW REAR TIRE ZW9 - CHASSIS CAB BODY
ZY1 - SOLID PAINT Z85 - HANDLING/TRAILERING SUSP PKG
Z88 - GMC TRUCK NAMEPLATE 1SA - WORK TRUCK PACKAGE INCLUDES: *CHASSIS CAB BODY *AM/FM STEREO *CHROME FRONT BUMPER
1SZ - HD PWR PKG SAVINGS 6GL - SPRING COMPTR SELECT FRT LH
69D - DARK PEWTER 69I - DARK PEWTER INTERIOR TRIM
7GL - SPRING COMPTR SELECT FRT RH 74U - FIRE RED
Vehicle Component
Help
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : R - CPC MORAINE,OH
Part/Num Broadcast : YUL Traceability : 0856337
Date Scanned : 07/20/2006 Time Scanned : 19.04.00 Scan Station : 02
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : Y4R Traceability : 240221816
Date Scanned : 07/20/2006 Time Scanned : 20.11.00 Scan Station : 36
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : H6PS Traceability : H6P011665
Date Scanned : 07/20/2006 Time Scanned : 19.04.00 Scan Station : 07
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : GL Traceability : 0BK954610
Date Scanned : 07/20/2006 Time Scanned : 20.07.00 Scan Station : 03
Component Code : 61 - TRANSMISSION
Source Plant : L - ALLISON INDIANAPOLIS,IN
Part/Num Broadcast : ZT4 Traceability : 320781616
Date Scanned : 07/20/2006 Time Scanned : 19.21.00 Scan Station : 6O
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : J
Part/Num Broadcast : YNAY Traceability : 61361370
Date Scanned : 07/21/2006 Time Scanned : 09.38.00 Scan Station : 04
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 5015 Traceability : 00013011
Date Scanned : 07/20/2006 Time Scanned : 23.21.00 Scan Station : 33
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 8218 Traceability : 1GVCNQL
Date Scanned : 07/20/2006 Time Scanned : 21.17.00 Scan Station : 35
Component Code : AJ - IR-SENSOR ASM-RIGHT
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 0150 Traceability : 6152039NU
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 4516 Traceability : 9ABYG26
Date Scanned : 07/20/2006 Time Scanned : 19.22.00 Scan Station : 07
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 4782 Traceability : 26173LPSY
Component Code : CC - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0160640
Date Scanned : 06/30/2006 Time Scanned : 03.01.00 Scan Station : N/A
Component Code : CF - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1XB Traceability : 8359932
Date Scanned : 06/30/2006 Time Scanned : 12.48.00 Scan Station : N/A
Component Code : CK - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1MP Traceability : 8044952
Date Scanned : 07/20/2006 Time Scanned : 13.21.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1HP Traceability : 8318771
Date Scanned : 07/20/2006 Time Scanned : 16.25.00 Scan Station : N/A
Component Code : CN - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1HA Traceability : 3385692
Date Scanned : 07/20/2006 Time Scanned : 17.32.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1GA Traceability : 4161435
Date Scanned : 07/20/2006 Time Scanned : 18.13.00 Scan Station : N/A
Help
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 12/28/2006 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 25 miles
PO BOX 1304
(304) 485-4418
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 50593
Dealer Information
Help
INVOICE INFORMATION
Invoice Date : 08/28/2006
Site Address : MATHENY MOTOR TRUCK COMPANY
PO BOX 1304
Site Code : 50593
SHIP-TO INFORMATION
Ship-To Date : N/A
Site Address : MONROE TRUCK EQUIPMENT
901 JOLIET
JANESVILLE , WI 53545
Site Code : 63002
Business Associate Code : 149459
