Anyone Want A Gm Lockpick
sam5828
    • I have a hard time seeing oil from 'below' the rings 'pooling' in the cylinder. For an amount great enough to pool getting past the rings I would expect to see that same amount contributing to other noticeable symptoms, low compression, blow by, etc. You could try investigating for a stuck, gummed or carboned up ring, maybe an oil with different detergent strategy. Some other shade tree solutions like adding a detergent (or mystery oil) to the chamber and letting it sit, I've also heard of a heavy use of 'engine braking' to load the rings differently.   I would first be looking at oil entering from 'above' via a head issue, or intake/PCV issue. I suspect that the oil is entering cylinder 8 combustion chamber at all times but is getting burned off during each combustion event preventing a 'pool' from forming and lessening visible oil burning smoke. This leads back to valve stems or PCV system as the only route for oil to enter the chamber from. I would expect a PCV issue to not be isolated to cylinder 8 though.   Other considerations, how long does it take the pool to form? Could you look for the oil trail via the borescope? (Run the truck, shut the engine off, as quickly as practical, pull the plug and insert the scope and record to see how long and hopefully where from.)
    • National Average back up to $4.04 for gasoline and $5.35 for diesel.   https://gasprices.aaa.com
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
