Should I Use Tow/haul...
...when towing a 2200 lbs bass boat? i havent been using t/h and it does ok, but thought i would ask in case i'm stressing something.
Theres lots of info in the users manual regarding tow/haul, in particular if your vehicle has autoride. Here is what's in mine.
Tow/Haul Mode
Tow/Haul is designed to be most effective when the
vehicle and trailer combined weight is at least 75 percent
of the vehicle’s Gross Combination Weight Rating
(GCWR). See “Weight of the Trailer” later in this section.
Tow/Haul is most useful under the following driving
conditions:
• When pulling a heavy trailer or a large or heavy
load through rolling terrain.
load in stop and go traffic.
load in busy parking lots where improved low
speed control of the vehicle is desired.
Operating the vehicle in Tow/Haul when lightly loaded
or with no trailer at all will not cause damage. However,
there is no benefit to the selection of Tow/Haul when
the vehicle is unloaded. Such a selection when unloaded
may result in unpleasant engine and transmission
driving characteristics and reduced fuel economy.
Tow/Haul is recommended only when pulling a heavy
trailer or a large or heavy load.
Tow/Haul Mode
conditions:
Like he said but to answer your question, no. Use it only on hilly terrain. That light of load shouldn't tax your rig at all.
Yes!!!!
just got my 2000 model 2500 series back from the transmission shop, had to have the torque converter replaced.
I pull a 6000 # camper and always pull in 3 gear (my obs does not have tow mode) and still had to have transmission fixed.
my understanding that is why gm when with the tow mode, because so many transmissions were failing. People would not shift to 3 gear when towing, so they made it easier on truck by installing a tow mode.
Will not help, if people will not use it.
Just my two cents!!
also be sure to have transmission serviced regular. Very expensive to repair.
what about just driving in the moutains? I was just in WV the past weekend and drove to the highest elevation (Spruce Knob). I used the tow/haul mode because my tranny was shifting up and down like a mad man as my tranny temp kept clinmbing. so when i used T/H mode it did great - didn't down shift as much and tranny temp when way way down ( from close to 200 down to 130).
not sure if this is what T/H mode was intended for since i had no boat to tow, but just a few hundred #'s in the back. i figured dropping it into 3rd wouldnt help since i was in and out of second so much.
Doesn't T/H change the shift points to a higher RPM and actually increase line pressure some? I have noticed that the shifts are definitely firmer with T/H engaged.
When towing heavy loads, it's a good idea to not place the shifter in D so that the OD will not engage. Constant in and out of OD or shifting will create excessive heat in the tranny and will eventually damage the internals.
I also believe that the factory tranny cooler that is installed as part of the trailering package is less than adequate for towing heavy loads. Although it's a stacked plate design, a much larger cooler will help to keep the fluid temps down and thus saves the tranny.
it does change the shift point. i don't know about line pressure, but it does seem that way.
T/H mode is supposed to keep it from hunting. If the tranny is hunting you are correct that you should take it out of OD but if it doesn't then keep it in OD.
With my T/H on my rig doesn't hit OD until at least 65mph. But if I'm in hilly country pulling the boat I just leave it in 3. I hate seeing the tach at 2500 RPM going 60mph, but it keeps the tranny nice and cool and SUCKS down the gas.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
