Vin Run For Build Sheet And Service History
smokepig
Can anyone provide me with a Service history report and or Rpo code details for a 2001 Chevy Tahoe I just bought it a couple of weeks ago and would like to know some of the details of this vehicle. VIN 1GNEC13T41R225860
Thank you
Keith
VEHICLE BUILD
Merchandising Model : CC15706 -2001 TAHOE 2WD
Gross Vehicle Weight Rating : 3087 kg (6807 lb) Order Number : DJBTR8
Build Date : 07/17/2001 Build Plant : 11R06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS ARL - PLANT CODE-ARLINGTON, TX
AS3 - CENTER AND REAR SEATS AT5 - FOLDING CENTER SEAT
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER AXP - MPV VIN IDENT POSITION
A31 - POWER WINDOWS A95 - RECLINING BUCKET SEATS
BVE - ASSIST STEPS B30 - WHEELHOUSING & FLOOR CARPETING
B33 - REAR COLOR KEYED FLOOR MATS B37 - COLOR-KEYED FRONT AND REAR MATS
B85 - BRIGHT BODY SIDE MOLDINGS C25 - REAR WINDOW WIPER & WASHER
C36 - REAR HEATER C49 - ELECTRIC REAR WINDOW DEFOGGER
C5U - GVW RATING - 6,800 LBS C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
C69 - AIR CONDITIONING-FRONT & REAR DF5 - INT R/V MIRROR, LIGHT SENSITIVE W/OUTSIDE TEMP & COMPASS
DH2 - LIGHTED LH & RH VISOR MIRRORS DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER
DK7 - INTERIOR CUSTOM ROOF CONSOLE D07 - CUSTOM FRONT FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT E52 - LIFTGATE/LIFTGLASS
FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS FK2 - TORSION BAR SPRING ADJUSTMENT
FK3 - TORSION BAR SPRING ADJUSTMENT GT4 - REAR AXLE - 3.73 RATIO
G65 - LEVEL CONTROL MAN,SELF ADJUSTIN G80 - LOCKING DIFFERENTIAL-REAR AXLE
JC5 - 4 WHEEL POWER DISC BRAKES KG8 - 130 AMP GENERATOR
KNP - HD AUX TRANSMISSION COOLING SYS KUP - THROTTLE CONTROL ELECTRONIC
K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER
LM7 - VORTEC 5300 V8 SFI GAS ENGINE M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE
NF2 - FEDERAL EMISSION SYSTEM NP5 - LEATHER WRAPPED STEERING WHEEL
NW7 - TRACTION CONTROL POWERTAIN MGMT PF4 - CAST ALUMINUM WHEELS (REPLACES WHEELS IN PACKAGE)
QE4 - WHEEL SPARE 16 X 6.5, ALUMINUM QMK - P265/70R16 WOL TIRES
R9F - TRACTION PACKAGE INCLUDES: *TRACTION ASSIST/RECOVERY HOOKS *LOCKING DIFFERENTIAL R9I - TRAILER PACKAGE INCLUDES: *TRAILER HITCH PLATFORM *7-LEAD WIRE HARNESS CONNECTOR
R9J - THIRD ROW SEATING PACKAGE: *THIRD ROW SPLIT BENCH SEAT *PREMIUM SUSPENSION *REAR HEAT *P265/70 R16 TIRES SLM - STOCK ORDERS
T96 - FRONT FOG LAMPS UP0 - AM/FM STEREO W/CASS & CD PLAYER (REPLACES RADIO IN OPTION PKG)
UQ3 - ENHANCED AUDIO SPEAKERS UY7 - HD 7-LEAD TRAIL. WIRING HARNESS
VB3 - CHROME REAR STEP BUMPER VG3 - FRONT DELUXE CHROMED BUMPER
VP6 - NOISE CONTROL VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL V22 - DELUXE FRONT APPEARANCE PKG.
V54 - BLACK ROOF LUGGAGE CARRIER V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKS XMK - TIRE FRONT P265/70R16-111S WOL
X88 - THIRD ROW FLOOR MAT DELETE YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING YE9 - LS TRIM
YMK - TIRE REAR P265/70R16-111S WOL ZMK - SPARE TIRE P265/70R16-111S WOL
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT 1SB - LS PREFERRED EQUIP GROUP INCLS: * VORTEC 5300 V8 ENGINE * AM/FM STEREO W/CD PLAYER * 9 SPEAKER SYSTEM W/SUBWOOFER * CRUISE CONTROL W/IP TELLTALE * REMOTE KEYLESS ENTRY W/ALARM * ISRV MIRROR W/COMPASS & TEMP * FRONT & REAR AIR CONDITIONING * LEATHER WRAPPED STEERING WHL * ENHANCED SUNSHADES * POWER WINDOWS * MACHINED CAST ALUMINUM WHEELS * DUAL PWR HEATED OSRV MIRRORS WITH GROUND ILLUMINATION * BODY SIDE MOLDINGS
1SZ - PREFERRED EQUIPMENT SAVINGS 12I - GRAPHITE INTERIOR TRIM
122 - GRAPHITE/MED GRAY LEATHER TRIM 6XN - COMP FRT LH COMPUTER SEL SUSP
7XN - COMPONENT FRT RH COMP. SEL SUSP 72U - 72 REDFIRE METALLIC
© 1998-2005 General Motors Corporation. All Rights Reserved.
VIN : 1GNEC13T41R225860
CLAIM HISTORY
Repair Order Date : 05/16/2007 Repair Order Number : 185687 Odometer Reading : 43860 miles
Serviced By : PEOPLE S CHEVROLET
580 AUTO PARK DR
CHULA VISTA, CA 91911-6026
(619) 421-3300 Selling Source : 13 - CHEVROLET
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
06/08/2007 802 01 B E2320 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - RIGHT - REPLACE 15233112 - HUB Y
Repair Order Date : 08/27/2004 Repair Order Number : 411416 Odometer Reading : 35000 miles
Serviced By : GM ROADSIDE ASSISTANCE
PO BOX 50098
PHOENIX, AZ 85076-0098
09/03/2004 514 01 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) N/A N
Repair Order Date : 08/25/2004 Repair Order Number : 250023 Odometer Reading : 36358 miles
Serviced By : MAROONE CHEVROLET OF PEMBROKE PINES
PO BOX 848480
PEMBROKE PINES, FL 33084-0480
(954) 433-3300 Selling Source : 13 - CHEVROLET
09/14/2004 517 01 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 88982293 - MODULE Y
09/14/2004 517 02 # N0110 - BATTERY - ONE - REPLACE 19001632 - BATTERY Y
09/14/2004 517 03 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE N/A Y
Repair Order Date : 06/24/2004 Repair Order Number : 239272 Odometer Reading : 35087 miles
PO BOX 848480
08/24/2004 511 01 # D1180 - SWITCH, PRESSURE CYCLING - REPLACE 89040362 - SWITCH Y
08/13/2004 508 04 # Z7905 - 5-DAY COURTESY TRANSPORTATION N/A Y
08/10/2004 507 02 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS N/A Y
08/10/2004 507 03 # K9995 - CUSTOMER CONCERN NOT DUPLICATED N/A Y
Repair Order Date : 06/23/2003 Repair Order Number : 148536 Odometer Reading : 21450 miles
PO BOX 848480
07/01/2003 391 01 # F1610 - SEAL, AXLE SHAFT OIL - REAR AXLE - RIGHT - REPLACE 12471686 - SEAL-R/AX Y
Repair Order Date : 12/31/2002 Repair Order Number : 105267 Odometer Reading : 17258 miles
PO BOX 848480
01/07/2003 341 01 # V0894 - 02039 - INSTALL PROTECTIVE COVERS 88880048 - COVER KIT Y
Repair Order Date : 07/15/2002 Repair Order Number : 387347 Odometer Reading : 11526 miles
PO BOX 848480
07/26/2002 294 01 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 15054698 - CONTROL Y
07/26/2002 294 02 # Z7901 - 1-DAY COURTESY TRANSPORTATION N/A Y
Repair Order Date : 07/17/2001 Repair Order Number : A25860 Odometer Reading : 0 miles
PO BOX 848480
07/20/2001 188 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
