How To Find What Model Number For Getting The Correct Nav For A 2008 S
How To Find What Model Number You Need For A 2008 Silverado LT1?
And does anyone know a website that shows pictures of the install from a non-Bose system to get NAV system?
good luck changing over there is alot of stuff you need to do to get it to work, i would go with aftermarket
If you go with after market do you lose onstar, XM and Wheel controlls?
No, you would not lose the Onstar if you get the wiring harness adapter...As for XM, you may be able to reuse the antenna but your radio ID would change. I have a Pioneer AVIC-D3 nav setup and my Onstar still works.
I'm also curious which model number should be purchased for a non-Bose '08.
Hello all. My company has all factory GM naviagation radios applications for 2003-2008 vehicles. All of our units are plug n play, and will not lose any of the factory vehicle options.
Please feel free to contact me direct for further information.
800-323-4813
Adam
This guy helped me out alot.
Eltonmc, you say he helped, could you elaborate? I think there are alot of people in the same situation as you (Like me) that would like to do the upgrade but nobody seems to have ever completed it and posted how.
Thanks
Thanks
This guys company sells brand new Factory Nav and set it up for your truck vin number.... They are very $.
So I decided to go with the AVIC-D3 which is on sale at Best Buy this week for 699.99 did the install in about an hour and kept steering controlls and onstar...... I will post pics if anyone would like to see.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
