Autolock Differential
vhbigman
Tech,
I have an 07 nbs GMC sierra crew cab 4x4. What oil type is recommended for changing out the front differential, are any additives are needed, if any, and what is the capacity. Also for the rear with the G80 locker are any additivies needed and what is the capacity. For the additives and oil what are the GM part numbers?
thanks
v
I have heard different opinions about fluid intervals, I guess it is dependent on the driving habits of the driver. Some claim 12-15k intervals and others 30k. I assume frequent towing decreases the time interval of changing the fluid.
v
I don't really go on intervals you can see the quality pretty easily by looking at the fluid and I check mine every time. I never really kept track of any but I don't think there is a recommended interval :) plus I'm too lazy to look it up. Which front axle do you have?
Not quite sure but i have the traction control system and vin 2gtek133571652963
also the rear does not require any additives, right?
v
Application
Type of Material
GM Part Number
Differential Carrier Assembly Case Mating Surfaces
Sealant
GM P/N 1052942 (Canadian P/N 10953466) or equivalent
Electric Motor Actuator
Sealant
GM P/N 12346004 (Canadian P/N 10953480) or equivalent
Front Drive Axle (8.25" S4WD Axle)
Lubricant
GM P/N 89021671 (Canadian P/N 10950849) or SAE 80W-90 GL5
Front Drive Axle (8.25" F4WD Axle, 9.25" Axle)
Lubricant
SAE 75W-90 Synthetic Axle Lubricant GM P/N 89021677 (Canadian P/N 89021678) or equivalent meeting GM Specification 9986115
Front Drive Axle Inner Shaft Housing to Differential Carrier Assembly
Sealant
Pinion Yoke Splines
Sealant
Application
Type of Material
GM Part Number
Rear Drive Axle
Lubricant
SAE 75W-90 Synthetic Axle Lubricant 89021677 (Canadian P/N 89021678) or equivalent meeting GM Specification 9986115
Ring Gear
Marking Compound
1052351 (Canadian P/N 10953497) or equivalent
Pinion Gear Bearing Retainer
Sealant
Pinion Yoke Splines
Sealant
thanks for the info
v
Application
Type of Material
GM Part Number
Sealant
Sealant
Lubricant
Lubricant
Sealant
Pinion Yoke Splines
Sealant
Application
Type of Material
GM Part Number
Rear Drive Axle
Lubricant
Ring Gear
Marking Compound
Sealant
Pinion Yoke Splines
Sealant
