03 Yukon Xl Denali Shocks
Tage
My SUV has almost 100K miles on it and it rides like crap. My lowered Honda is much smoother over most roads. I'm guessing my shocks are just worn out not doing much and replacing them would be a good idea. After some research some people are saying it's a bad idea to replace them with anything besides the original shocks since it will throw a check engine light and the traction control may not work anymore. I'm fine with that but I'm finding they are super expensive.
Checking on online I'm finding several super low mile OEM shocks off a 2007 Denali for a fraction of the cost. Are 2007 Denali shocks the same as 2003 Denali shocks? Any difference between the regular size vs XL?
In case it matters, the VIN is 1GKFK66U23J144492
While I don't have access to the parts catalog, I would bet they won't work. However, if no-one else has answered you by Monday, I will go to parts and check for you.
Tage,
I cannot be sure, but does your Denali have the Autoride electronic controled shocks? If so, they are very expensive. I have read a few posts where people have replaced them with traditional shocks.
You could have the Premium Smooth Ride option which is ZW7 I think. If so, the front shocks are typical shocks but the rears are called "self leveling" and made my Sachs. You have to replace them with the same type shock and to my knowledge, nobody makes them other than Sachs. Our supplier, KYB offers them but they are repackaged from Sachs. Our part # is SR 2004 but be ready, they are very expensive. I have also read you can replace them with traditional shocks but you have to replace the rear coils as well.
If you do have the ZW7 option, I would recommend you go back with the same type rear shocks and KYB MonoMax shocks on the front. I still have my rear self leveling units but I have KYB Mono Max on the front.
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
