How? Emission!
4wd
I understand Emission Control is not only the cats, it involves a change of the fuel, air and spark level when the reading from the first O2 sensor is not within a range, which results into many perfromance issues....
Now, how can I avoid these problems as I am planning to use my truck in the desert wher it is very hot and bad wether?? do tuners fix/bypass this?
My mistake! this post should not be here!
