Knocking From My Steering? Or Suspension?
I have a 2006 GMC Sierra 1500 4x4. I recently noticed a knocking sensation coming from the steering when I turn any degree to the right. The wheel does not shake but you can feel a knock either from the suspension or steering in the steering shaft. I can feel it at any speed to the right and only over 45 when going to the left so that would be like getting off exit ramps on the highway. The truck has 16,000 miles so I can take it in under warranty but I just wondered what this could be until I do take it in. It getting a little worse each week. I have been told that these trucks has bad steering shaft designs and replacing it will not do any good??? Thanks a lot for the help.
Sounds like the intermediate steering shaft to me. Had mine replaced with the new one and it has been fine ever since. Definatly take it in and have it replaced. Mine was done with 50k on it under warranty.
Thanks a lot. I was surprised something would go bad that quick with those miles. Its had a hub assembly, 3 belts, and some exterior chrome stuff replaced like the wheel, grille, etc. but at least its covered! I will have the shaft looked at. Had a friend who has the same thing happen and they replaced his as well.
id get a bosgeson unit they are way better than the oem ones, then youll never have to worry about it again
they may even take it out re grease it and put it back in and that will last awhile.Putting an new one in with the same design probably won t be any different after a while. Just plan on getting it grease every so often.
Go ahead an replace. We replace quite a few of the steering shafts on many of our GM vehicles at the dealership I work at. Just one of the weak points of many GM vehicles.
Thanks a lot. The hard part is convincing them to replace it when they only want to regrease it! I usually have to get a little forward with my dealership to get something replaced. I really find it irritating more than anything. Lubed my belt 3 times before they would replace it and never looked into my squeeking hub until it went bad...they said it was nothing 2 times on that. If they just gease it, I will take it Chevrolet down the street. I had the truck filled with 600+lbs of soil and debris and it lightened up on the knocking. Still pulled like a good ol Chevy though! Thanks again
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,531 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
