Nbs Seat Wear!
I'm having my lower part of my driver's seat replaced already. I only have 32,000 miles on my truck. Now before you say anything about my weight I have a '01 Dodge Diesel with over 250,000 miles and still no tears and I only weigh 175lbs. I thought it was bad enough with the lint problem and now this. What do they call it premium cloth for?
Because based on THEIR costs vs what you pay, it gives GM a premium :(
I must say, I got the "premium" non-leather interior on my GMC NBS as well (never a big leather fan), and am already seeing waves in the fabric and things I wouldn't expect to see at 12,000 miles (!)
I plan on bringing that up at my next dealer visit to have them look at it.
I am also seeing what I would consider "pre-mature" wear, based on my experience with my previous trucks.
same with my leather...it looks almost in bad shape already.
Your post has me concerned.
I'm only at 11K miles and I don't weigh much (under 150) but I sure hope that the leather on the 08 wears like the leather on the 99. My 99 leather is still in awesome condition after 9 years in the Texas heat and 127K miles. Sure the 99 leather has a shiny patina from all the years of use but it has hardly any wear. The vinyl on the side of the side is cracking but the leather is holding. Even the armrest is holding up well. I do clean and condition the leather at least twice a year. I wish the leather on my 97 SL was a durable as the 99 Chevy...sure it's softer, nicer feeling leather but it's getting worn pretty badly after 11 years and 90K miles (it was my dad's car, so I know it's not due to weight).
Yeah my dads 2000 silverado's leather is shot. There are at least three hole and is cracking bad. Mine isnt nearly as bad, but you can tell a difference from the passenger sit. Only conditioned it once, but i think the main issue is direct sunlight (considering i only weight 150)...tinting the windows helps a lot.
  • 2 years later...
I would like some feedback on the NBS cloth seats from some of you with NBS trucks that have put 50k miles or more on the truck. The cloth on the drivers seat on my 2010 2500HD is showing wear already with less than 10k miles. It's hard to imagine what the seat may look like by the time it has 100k on it.
They call it premium because they get a premium price for it. I've driven GM vehicles since 1971 and I've never had good luck with any of their seat fabrics. My new and improved fabric on my 10 Sierra is actually no better than the 08 or the 09 fabric. I gave in and bought seat covers.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
