O1 Security Anti Theft System
No, the factory security is not enough. Buy an aftermarket alarm with motion/shock sensor, ignition disable, and a dash mounted LED light, visible from both front doors. Check out http://www.trucksecurity.com for more security options. Also, http://www.autoguard.us for the hood latch protector, and watch the video link, (upper left corner). You can also buy "rear crew cab door handles", or "Escalade chrome rear door handles", with out, key holes, and install them, on the front doors. I would also buy a Stant locking gas cap, Mcgard or Gorilla locking wheel lugs, and an extra spare tire rod/cable lock too. And, buy a Pop-lock or Bully locking tailgate handle. This may sound like too much, but it will detour theft.
The factory setup is a content theft alarm, and thus is designed to basically sound if the door is unlocked without the use of the key or remote. If someone were to break the glass and reach in, you're out of luck.
I'm not worried so much about any contents of the truck being stolen, I'm more concerned about the truck itself. The GM Passlock system is supposed to disable the fuel system. My question should have been more specific. Is the Paslsock system sufficient. Anyone know of a truck being stolen regardless of this system?
If someone wants to take your truck, they are going to take it. It doesn't hurt to use other security products to help, but I figure if someone wants mine that bad, nothing is really gonna stop them.
I had the early warning Lo-Jack installed in mine. I figure with Onstar, E/W Lo-Jack, the vehicle alarm, and the club there are alot of systems to defeat. With all that said, like stated above if they want it they will get it, but I will make it as difficult as I can.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
