Coolant Loss !
jocko50
I have a 99 Silverado with 5.3L and it has 102,000 miles. Problem that i am having is that i am losing coolant. Light comes on in truck and sure enough its down past the minimum in the resivor. Fill it up and i am ok for about 2 weeks and same thing over and over. Truck runs fine, Dry plugs, no external leaks(water pump etc) Pressure tested OK. Took valve cover off and found this butterscotch looking stuff stuck to the inside valve cover(coolant???). Any info greatly appreciated. Are these 5.3L known for this type of problem? I was told Intake gaskets will not solve this problem. Are head Gaskets next?? Thank you. :lol:
Any butterscotch on the dip stick?
No, Doesn't seem to be any in the oil. Only thing in the oil is some light sludge (black) which seems to be from engine cleaner Additive which was put in to motor a while ago. The valve train looks a little dirty(from previous owner not changing oil often)? Thanks for reply!!
Do a pressure leakdown test on the cooling system to see if there is a leak (either internal or external). My guess is that you have a headgasket leak somewhere...
I have already done a pressure test and it held up fine. Did one test cold and one hot and no leaks. Thank you for your time. I don't want to do any repairs that i don't have to but it is looking more and more like a head gasket. Anything else you can suggest?
Jocko,
When you are trying to diagnose a problem it is always a good idea to start with the small things first. I had a problem like this a while back with an 86' monte carlo I had. Every month or so it would leak an entire reservoir worth of coolant. No leaks anywhere, no coolant in the oil. Stumped me for months. Turns out I had a hairline crack on the underside of the radiator hose that when the thermostat opened pressurized the upper radiator hose and allowed coolant to run down the radiator and pool on the lower radiator support. When the engine warmed up more, the rubber swelled and it stopped leaking, then when it got hot enough it boiled off all the pooled coolant at the bottom. Only reason I figured this out was that one side of my radiator turned green from the coolant. My point is, when faced with a big problem, take it one step at a time. I hope this helps.
I have a 99 Silverado with 5.3L and it has 102,000 miles. Problem that i am having is that i am losing coolant. Light comes on in truck and sure enough its down past the minimum in the resivor. Fill it up and i am ok for about 2 weeks and same thing over and over. Truck runs fine, Dry plugs, no external leaks(water pump etc) Pressure tested OK. Took valve cover off and found this butterscotch looking stuff stuck to the inside valve cover(coolant???). Any info greatly appreciated. Are these 5.3L known for this type of problem? I was told Intake gaskets will not solve this problem. Are head Gaskets next?? Thank you. :D
On my 1999 silverado, I was loosing coolant too. Resivior would be low and I would refill it, and about 2 weeks later, coolant low again. I seen no visible leaks, cold or hot, but noticed a white (alkali) water line, on the bottom of the oil pan. I traced it to the water pump "seep hole" and replaced the water pump. This occured around 95,000 miles. It probably leaks while your driving (under pressure).
Thanks for your help guys. I guess i will start with the water pump gasket first(and replace thermostat while im there) and see what happens. process of elimination as they say!!!!
Thats the way to do it. :thumbs:
I had a 98 Z71 that was doing the same thing. I found it the hard was as it was the heater hose fitting and it exploded later. They are made of cheap pot metal and will break down over time. I replace it with a steel one from NAPA for about $7.00.
  • 1 month later...
Well after checking a few easy things first like hoses and clamps and inspecting water pump and surrounding area i decided to replace the intake manifold to try and solve the loss of coolant issue i was having. I came to this conclusion by reading a post somewere here about Dextrol coolant and air coming in contact with it which will produce a butterscotch residue. I know the intake is a "dry system" but it seems to have solved the problem for now. Over 3000 miles and NO COOLANT LOSS !!!!!!. Maybe air was getting buy the gasket and some how mixing in with coolant through those tubes??? Now if i could only get rid of that Horibble Piston slap everymorning now that it getting a litlle colder outside. Truck sounds like a disel for a minute. THANK YOUS.
Well by "the book" It says its a 5 hour job but i had my mechanic friend do it for me after i told him to change that gasket because he did not want to make the call because he was stumped at what it could actually be. We both had our opinions but it was my call. Hope this is a long term soloution.
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,357 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
