First Oil Change
Ok guys 'm not starting any wars just looking for some advise. My truck has 804 miles and 91% oil life. When I got the truck it had 22 miles on it. When does everyone do there FIRST oil change? Sorry but this is my first new truck in 10 years. By the way it's a 5.3L.
IDK about the 5.3 but in my buddies 3500HD Durmax they told him to get it changed around 1,000 IIRC... After that they said change oil when the change oil light says so.
I changed mine @ 1000 miles, then 3000 miles, and there after @ 5000 miles.
Have a good one,
Don
Thats my schedule. I just did the 3000 one, but after the 5,000 I will do it at about 3-5k.
Have a good one,
Don
that's a good schedule and one everyone should keep. I run Mobil 1 Synthetic
Thanks Guys I will change it at 1000 miles. I always use full synthetic oil.
You could change it now, but don't go past 1,000 miles. If you've never had a new vehicle/engine before, you will be surprised at the amount of metal in the drain oil. But don't worry, that's perfectly normal, and is the reason for doing the first oil change so early.
I do it at the first 1,000 miles,then every 3,000 there after.
Don't go over 1000. Here is my oil sample report at 607...that crap is nasty! Dirt, wear metals, etc. All normal for a new engine or overhaul, but no need to keep it in there longer than you have to.
oilsample.pdf
oilsample.pdf
oilsample.pdf
oilsample.pdf
I'd do mine at every 3,000mi if full synthetics didnt cost so much and if I drove it harder... Most of my driving is highway and even after 5,000mi the oil hardly looks dirty (Amsoil).
I try to do mine every 6,000mi and no more then 8,000mi.
Good man!!! :rolleyes:
you're wasting money if you are changing every 3,000 with Synthetic or are you running conventional?
Valvoline 5w30 conventional for me.
ah yeah. well even the conventionals are going 5K now but I wouldn't go higher.
sorry, I didn't mean to question the lube king. I'll go sit in the corner now.
:rolleyes:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,149 Guests (See full list)
