2003 Yukon Xl Flex Fuel Filter
I did not use a tool to remove it and just used a pair of pliers to hold down the tabs on the quick connect (engine side), and pushed out the connector. Then I noticed a small O-ring, a metal washer and a black plastic sleeve in the pan I had under the filter.
Are there any parts in the flex line from the engine side of the quick connect that I had pulled out with the filter? I had to pound on the filter with a wood block to get it pushed out of the plastic retaining ring, as the filter housing was rusted. I am wondering if I knocked some parts out of the flex line connector or the tip of the flare nut on the tank side.
Any info on this will be greatly appreciated.
Man I wish I could help you. I have an 02 Flex Fuel Yukon XL and I am somewhat familiar with what you are talking about. I know what the retaining clips look like and how they release but am not aware on any o' rings. The tool typically used simply depresses both sides of the plastic retainer and allows the male end of the filter to be removed from the line. These retainers sometimes break and we do sell them for this reason.
Sorry I could not be of more help. You may want to post this in "Ask a Tech".
This may or may not help:
gmLogoFlat.gif Service Information
2003 GMC Truck Yukon XL - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 803493 Fuel Filter Replacement (4.8L, 5.3L, and 6.0L Engines)
Removal Procedure
Important: Clean the fuel filter connections and surrounding are before disconnecting the fuel lines in order to avoid possible fuel system contamination.
  2. Relieve the fuel system pressure. Refer to the Fuel Pressure Relief .
  3. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  4. Clean the fuel filter connections.
  5. Using a flare nut wrench and backup wrench, loosen the fuel lines (1) from the fuel filter.
  6. Remove the fuel filter outlet line from the retainer and reposition the line out of the way.
  7. Slide the fuel filter out from the bracket.
  8. Inspect the fuel line O-rings for cuts, nicks, swelling, or distortion. Replace the O-rings if necessary.
  9. If a restricted fuel filter is found, clean the entire fuel system. Refer to Fuel System Cleaning .
Installation Procedure
  2. Slide a NEW fuel filter into the bracket.
  3. Position the fuel filter outlet line and install it to the retainer.
  4. Tighten the fittings by hand until snug.Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  5. Using a flare nut wrench and backup wrench, tighten the fuel lines (1).Tighten
    Tighten the fittings to 25 N·m (18 lb ft).
  6. Lower the vehicle.
  7. Install the fuel fill cap.
  8. Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
  9. Perform the following in order to inspect for fuel leaks:
    8.1. Turn the ignition to ON, with the engine OFF, for 2 seconds.
    8.2. Turn the ignition to OFF for 10 seconds.
    8.3. Turn the ignition to ON, with the engine OFF.
    8.4. Inspect for fuel leaks.
© 2008 General Motors Corporation. All rights reserved.
2003 GMC Truck Yukon XL - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 803488 Fuel Pressure Relief
Tools Required
J 34730-1A Fuel Pressure Gage
Caution: Relieve the fuel system pressure before servicing fuel system components in order to reduce the risk of fire and personal injury.
After relieving the system pressure, a small amount of fuel may be released when servicing the fuel lines or connections. In order to reduce the chance of personal injury, cover the regulator and the fuel line fittings with a shop towel before disconnecting. This will catch any fuel that may leak out. Place the towel in an approved container when the disconnection is complete.
  2. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
  3. Install the J 34730-1A . Refer to Fuel Pressure Gage Installation and Removal .
  4. Loosen the fuel fill cap in order to relieve fuel tank vapor pressure.
  5. Open the valve on J 34730-1A in order to bleed the system pressure. The fuel connections are now safe for servicing.
  6. Drain any fuel remaining in the gage into an approved container.
  7. Once the system pressure is completely relieved, remove the J 34730-1A .
2003 GMC Truck Yukon XL - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 803489 Fuel Pressure Gage Installation and Removal
Tools Required
Caution: Gasoline or gasoline vapors are highly flammable. A fire could occur if an ignition source is present. Never drain or store gasoline or diesel fuel in an open container, due to the possibility of fire or explosion. Have a dry chemical (Class B) fire extinguisher nearby.
Caution: Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
  2. Remove the engine sight shield. Refer to Upper Intake Manifold Sight Shield Replacement in Engine Mechanical-4.8L, 5.3L, and 6.0L.
  3. Remove the fuel rail pressure fitting cap.
  4. Connect the J 34730-1A to the fuel pressure valve. Wrap a shop towel around the fitting while connecting the gage in order to avoid spillage.
  5. Install the bleed hose on J 34730-1A into an approved container.
Removal Procedure
  2. Remove the bleed hose on the J 34730-1A from the approved container.
  3. Remove the shop towel from around the fitting and discard into an approved container.
  4. Disconnect the J 34730-1A from the fuel pressure valve.
  5. Install the fuel rail pressure fitting cap.
  6. Install the engine sight shield. Refer to Upper Intake Manifold Sight Shield Replacement in Engine Mechanical-4.8L, 5.3L, and 6.0L.
2003 GMC Truck Yukon XL - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 824711 Upper Intake Manifold Sight Shield Replacement (4.8L, 5.3L, and 6.0L (RPO LQ4))
Removal Procedure
  2. Loosen the intake manifold sight shield bolt.
  3. Remove the sight shield from the sight shield retainer.
  4. Remove the sight shield retainer bolts and the retainer, if required.
  2. Install the sight shield retainer and the bolts, if required.Tighten
    Tighten the bolts to 5 N·m (44 lb in).
    Notice: Use care when installing the engine sight shield to avoid contacting the manifold absolute pressure (MAP) sensor wire harness connector. Loss of engine performance or engine damage may result.
  3. Install the intake manifold sight shield to the retainer.Tighten
    Tighten the bolt to 10 N·m (89 lb in).
Thanks for the infos.
Looks like I goofed up the female quick connect's internals and now need to change to whole flex fuel line and quick connect. Anyone knows the part number for this item, or where Ic an get it?
It is roughly a 12" long flex fuel line that connects from the engine side to the fuel filter. It has a metal push on quick connect on the filter side, and a push on quick connect with metal locking clip on the engine side.
    • Glad it worked for you. I tried that 1st, about 2 years ago. Didn't help. I also tried doing a hard reset (disconnecting battery for minimum of 30 minutes). Worked a couple times, but after one summer of doing it over and over, that no longer worked.  I was fairly confident it was either the compressor or a failed actuator, but I just couldn't identify which one. Had to research which actuators do what and which last numbers are associated with each.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices   In case that link doesn't work, here's the YouTube link:     And another 15 minutes to find this clip out of Glenn Beck's video - the first few seconds is all the corporate media will allow the public to see, since the low IQ people will think Trump said " I love inflation ", and that was the end of it. Taken WAY out of context! Here's that part, plus the 2nd part about the oil smuggling operation:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
