Is There A New Gm Rule On Wheel Replacement?
I have a 2006 GMC Sierra SLT with the factory 20" chrome wheels. This past December a wheel was starting to flake on the inside edges of the wheel face so the dealer replaced it. This time 2 more are going (not the new one) and they told me that GM has a new policy on blemishes for wheels. They must be seen from 3 ft away or they will not replace it. Its flaking! Depends on whos doing the looking I guess. I can see it and my vision is not perfect! Anyone out there work at a dealer know if this is even true? I cant believe that GM will not replace a defective wheel. Its going to just get worse every time I put a rag on it and wipe the wheel dry! Thanks a lot.
Here is the info:
gmLogoFlat.gif Service Information
2006 GMC Truck GMC C Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 2125601 #PIT4636: GM Accessories Wheel Appearance Standards - keywords accessory aesthetics blister chrome ding dent dust peel rim wheel - (May 1, 2008)
Subject:GM Accessories Wheel Appearance Standards
Models:1996-2009 GM Passenger Cars and Light Duty Trucks (including Saturn)
2009 and Prior HUMMER H2, H3
2005-2009 Saab 9-7X
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
GM Dealers and ADIs may occasionally question the initial quality of a GM Accessories Wheel Assembly from an aesthetics perspective.
Recommendation/Instructions:
When in doubt, the general rule that should be followed (as approved by GM Tire & Wheel Systems) is:
"No visible defects with the wheel in car position in daylight at a distance of 3 feet."
Otherwise, GM Dealers should reference TSB 07-03-10-015A to determine which issues are covered under warranty and which are not for plant-installed (OE) wheels as well as GM Accessories Wheels that have already been installed on a customer's vehicle.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
Document ID: 2093416 #07-03-10-015A: General Motors New Vehicle Wheel Warranty Coverage - (Apr 7, 2008)
Subject:General Motors New Vehicle Wheel Warranty Coverage
2005-2009 Saab 9-7X
This bulletin is being revised to add the 2009 model year and to simplify the Warranty Information. Please discard Corporate Bulletin Number 07-03-10-015 (Section 03 -- Suspension).
The General Motors New Vehicle Wheel Warranty
This bulletin has been issued to clarify warrantable conditions on GM OEM wheels. It is our intent that this one document will answer many of the warranty scenarios you are likely to encounter. Unlike other parts of the vehicle, wheels encounter various road hazards, corrosive substances and abuses that may present questions in both the mind of the customer and the dealer. Eligible conditions are warranted for the full term of the New Vehicle Warranty.
Information Sources for Wheel Issues
The following GM Service Bulletins contain information useful to minimizing possible damage, and reducing customer concerns that may arise through incorrect servicing and improper cleaning products.
#00-03-10-002D - Chemical Staining, Pitting, Corrosion and/or Spotted Appearance of Chromed Aluminum Wheels
#04-03-10-012A - Pitting and Brake Dust on Chrome Wheels
#06-03-10-004 - Proper Use of OEM Service Wheel Weights, Marring and/or Damage Due to Use of Non-OEM and/or Incorrect Wheel Weight Installation
#06-03-10-010 - Information on Proper Wheel Changing Procedures and Cautions
What is NOT Warrantable
GM provides many different styles and finishes for our passenger car and truck wheels. You will find both steel and aluminum wheels with painted, polished or chrome finishes available. While each of these types must meet GM durability standards for road impacts and finish appearance, there are conditions that are not warrantable.
Curb Impact / Scrapes
Wheels that have been damaged through abuse are not warrantable. Finish scraping and wheel flanges that have been damaged due to curb impact are not warrantable.
Bent Wheel Flanges / Cracked Wheels
Bent wheels and cracked wheels due to road hazards are not warrantable. In many cases bent and cracked wheels result from driving on low tire air pressure or a flat tire. Low tire pressures dramatically reduce the impact protection the wheel has and lowers the threshold where damage may occur.
Finish Damage / Streaking / Pitting / Corrosion
There are many different types of finish damage possible, resulting from aggressive cleaning products, road chemicals, poor tire changing practices, or manufacturing processes. Some of these are warrantable while others indicate abuse. See the Finish Damage sections below, which give examples of the different types of specific finish concern issues you may encounter.
NON-Warrantable Examples
The following are examples of actual wheels that were returned to General Motors under the New Vehicle Warranty and have been analyzed and reviewed.
The wheel above exhibits typical wheel rim damage on the inboard flange, caused by a road hazard. Customer comments may be vibration, air loss, or a wheel that cannot be balanced. This damage is not warrantable and a Warranty Parts Center (WPC) Regional Feedback Report was issued on this wheel. (Most WPC Regional Feedback Reports result in a chargeback of the warranty claim to the dealership.)
Important: Customers whose vehicles have sustained road hazard damage due to poor road surfaces on county or state roads may have recourse through their insurance company or through the county or state road commission. These policies vary by area. Contact your country or state government to check eligibility.
The photo above illustrates a crack in the wheel from a road hazard. In addition to the damage seen in the photo, the flange of the wheel was bent in the same area. Customer comments may include, vibration, air loss, or a wheel that cannot be balanced. This is not a warrantable condition and does not indicate any defect in the wheel. A Feedback Report was issued on this wheel.
The photo above is an example of the over-use of wheel weights to try to overcome another issue. This wheel has a bent outboard flange exactly 180° from the application of 79 1/4oz. (7 gr.) wheel weights! This condition is both not-warrantable and an example of incorrect servicing. If a wheel and tire assembly will not balance, the wheel should be examined and checked for runout. The associated tire should also be checked for radial force variation.
This final example above is a chemical stain that can appear on chrome wheels. This is the result of using corrosive or acidic wheel cleaners. This type of stain appears most often when non-approved cleaners are used repeatedly, allowed to remain on the surface of the wheel, or not rinsed away thoroughly. This type of damage is not warrantable.
Important:: In some cases when this type of stain is not too severe, it may be possible to improve the appearance with certain chrome cleaner/polishes. Refer to GM Service Bulletin #00-03-10-002D for additional information.
Warrantable Issues
Any defects in the finish, balance, or structure of the wheel resulting from improper manufacture are covered under the New Vehicle Warranty for the full time and mileage limits of that warranty. Typical covered finish issues that you may encounter are:
• Flaky or pitted chrome on the visible wheel surface indicating poor adhesion of the plating.
• Polished or machined aluminum wheels that exhibit Filiform Corrosion (chalky white lines under the clear coating) This condition is warrantable, unless it is caused by incorrect wheel weight application and use.
• Wheel center caps that exhibit similar conditions to warrantable wheel concerns.
• Thin or poor paint finish quality on painted wheels. Bubbling / Flaking of the paint.
• Paint damage incurred during stick-on wheel weight changes. (See Stick-On Wheel Weight Paint Damage or Paint Flaking/Peeling Backside of Wheel)
• Flaking or peeling on backside surface of wheel indicating poor adhesion of the plating (See Stick-On Wheel Weight Paint Damage or Paint Flaking/Peeling Backside of Wheel).
One type of finish concern specific to chromed aluminum wheels is spotting or what appears as golden colored pits on the surface (See example above). This type of finish concern is not the fault of any manufacturing or durability shortfall. This dissatisfier results from corrosive road chemicals used for dust control in some areas. (Calcium Chloride) Wheels with this type of corrosion may be eligible to be warranted one time only. Please refer to GM Service Bulletin #00-03-10-002D for additional information.
Preparing Wheel(s) for Warranty Return
The wheels returned to General Motors for warranty coverage are evaluated by a team made up of representatives from Engineering, GM Service, Quality, and the manufacturing OE Wheel Suppliers. During review of returned wheels, a finite amount of time is available to evaluate each wheel. It may benefit your dealership to observe the following guidelines for returning wheels.
• Please mark the defect in the wheel. You may use a paint pen, grease marker or tape off the area. Many times the Repair Order is not clear as to the reported concern. Simply circling the area of concern on the wheel is sufficient.
• Clean the wheel if it is overly dirty. It is not required that the wheel be polished or detailed. Returned wheels covered over with dirt/mud create the possibility of overlooking a cosmetic flaw that was the subject of the wheel return, creating a possible Feedback Report.
• Treat the wheel with care before packing for return. Dismounted wheel rims can be scratched and bent easily if abused before packing. This type of damage can mimic road/curb damage creating a possible Feedback Report.
Removal of Stick-On Adhesive Backed Wheel Weights
Many "flangeless" design wheels require the use of stick-on or adhesive backed wheel weights. Improper removal of the wheel weights (on chrome plated wheels) may peel, scratch or flake the paint on the interior surface of the wheel. Normally this is of no concern, but on some vehicles with wheels that are of a very open design, the interior of the wheel may be a visible surface. Here are tips to aid the removal of these weights.
• Use ONLY Plastic tools for removal of the wheel weights. The best tools to use are commercially available plastic putty knives or a plastic accusative trim removal tool. Use the tapered end of the tool to remove the wheel weight. These plastic tools are delicate on the painted surfaces serving to "push" the adhesive off the surface rather than scraping.
• Any adhesive left on the wheel may be cleaned with an automotive adhesive remover such as 3M General Purpose Adhesive Remover #08984 or equivalent.
• In most cases you will not encounter any difficulty with OEM painted aluminum wheels. Fully painted wheels have a robust paint application process that cannot be matched and duplicated. Chromed aluminum wheels have an air dry paint applied to the back side of the wheel, which is applied over a chromed surface. If a chromed aluminum wheel paint on the interior of the wheel peels, refer to the section below.
Stick-On Wheel Weight Paint Damage or Paint Flaking/Peeling Backside of Wheel (Chromed Aluminum Wheels)
Under no circumstances should the wheel be replaced for this type of damage. Damage caused by improper removal, metal tool scrapes and gouges should not be submitted. If you encounter a wheel where the paint has peeled, you may repaint the backside of the wheel.
GM currently uses two all-purpose colors to paint the inside of the wheel area. Both colors are a flat paint available in a very light silver or dark silver. Follow all manufacturers instructions when refinishing and refer to the GM Labor Time Guide for Material Allowances noting the warranty information below.
Aluminum Wheel Paint Codes
Description
Paint Code
Light Silver Metallic
WA-303L
Dark Silver Metallic
WAEQ715Q
Warranty Information (excluding Saab U.S. Models)
Important: GM of Canada dealers/retailers: All wheels replaced under warranty must be held for the inspection and/or scrapping by a General Motors representative, except when requested for return to the WPC.
Use the following Labor Operation when repairing a vehicle under warranty.
You are allowed to claim ONE-HALF the total amount of allowable time and materials as only the back side of the wheel is being repainted in this operation.
Labor Operation
Description
Labor Time
A3330
Wheels, Aluminum - Color/Clear Coat - One
Use Published Labor Operation Time
Warranty Information (Saab U.S. Models)
Choose the appropriate labor operation based on repair:
Labor Operation
Description
Object Code
Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
7711004
Includes: R&R wheel
7711004
86
3-left or 4-right or 5-all (if more than one wheel)
01
04
1.2 hrs
Add
7711005
To Color Coat-each additional wheel
includes: R&R wheel (s)
0.8 hr
Add
1270101
Adj. Wheel Balancing
Quantity 1
Add
1270102
Quantity 2
Add
1270103
Quantity 4
What dealer you deal with?
Since yours are "factory" and not accessory,they should replace them.
sup rich...like what they did to Dealerworld (Global Connect)?
I guess,Hell I don't see any difference other than the links are just in different places,I mean all the same stuff is there.
Although I can't run a dealer locate for some reason,I was trying to locate an Impala SS today and couldn't get into the locate function.
Ha wow that is excessive... wouldn't the tire shop realize that?
Yeah,But when they told the guy he was going to have to buy a $3-400.00 wheel because he bent his...he probably freaked out on them!!
Thanks for the GM policy paper. I ran into my rep at Cochran of Monroeville when I picked up my truck. (it had the steering intermediate shaft replaced), and he wanted me to show him the bubbles. I did and he told me that GM was being pretty stiff. It does look like bubbling and my wheels are pretty spot free of any man-made problems so it was nothing I did. He told me if it gets a little worse to bring it back in and they will get it replaced. I still cannot believe GM came up with a 3 foot rule! Oh well, I still have a year on the warranty. Glad to hear its legit and my rep was real nice about it when I picked the truck up. Thanks again. By the way, my wheels are starting to look like the photo with the arrow sticker. Not as pitted yet, but bubbling in the corner of the spoke.
so is the new tranny warranty that it has to blow up and send fluid 3ft. before its covered? this is bull, plain and simple. what they are saying is that they are buying their chrome wheels in china or mexico and refuse to take responsibility for using sub-standard components. im really appalled
haha! Its hard enough as it is to chrome plate aluminum so they if they choose to plate instead of polish...they should be held responsible. I have some Denali 17" wheels for the winter and they look almost chrome and all look great. One is from 2000 and still holds its shine and it won't flake. Why chrome and spend $1,000 a wheel for replacement or hundreds for rechroming when you can have polished it. What can you do. I see the chrome flake off and bubble on most GM cars when they have chrome aluminum wheels...aftermarket chrome alum wheels do fine! They are nice wheels and I paid extra for them so I hate to see GM do this and not guarantee their craftsmanship. The dealer I took my truck to said GM denied 12 wheels they sent back and then the 3 foot rule came out.
    Markey
    Markey
  • Who's Online   1 Member, 0 Anonymous, 2,089 Guests (See full list)
