Ratteling In The Dashboard
This question is manily for the 03-07 (classic 2500 people). I keep getting ths rattleing vibration noise coming from inside my dash when on the highway doing 70-80 mph. I thought it had something to do with my aftermarket head unit's wiring harness so I placed it in a different location and it wasn't it. I also made sure my little speaker chime box was secured and have that mounted low under the steering wheel. The speaker chime box is a add on because I am using an after market head unit and the chimes no longer come through the speakers like it did in the stock stereo.
Anyway just trying to see if anyone else has experienced a rattleing vibration noise, or I have to do some more searching and try to identify where the noise is coming from.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
