Predator Vs Edge Programmers
just got the predator for my 07 NNBS sierra with 5.3L engine. I currently have the Edge programmer install in it but I got a good deal on the predator from a member of another forum. I uninstall my Edge with extreme setting and install the Predator with the diablo 93 tune with the DOD off and the tires adjusted.
This only had the v8r10 update on it from 12-0-07 so there might be more adjustment option then what I have now. If so let me know!!
I took it for a test drive and WOW I can spin the tires on take off!!! I was impressed that the delay was gone. Overall it did close to what the edge did but the edge had a little more. But I didn''t do any adjustments yet. The trans response is better on the edge which I like!!
OK I have pros and cons of each programmer
EDGE
Pros, 1. heads up display with alerts if it detect a problem and the option to change a tune where every you are because it is alway hooked up. 2. the trans has get shift points and shifts strong so there is no power loss. 3. Can adjust tire size ,gears, and speed limiter. 4. Easy for the operator to adjust and program with easy to follow display 5. there is more but they are the same with both programmers
Cons, 1. Still has delay on take off and TM. 2. DOD disable is not available. 3. No adjusting of settings like (timing, etc) 4. Can not import a custom tune
PREDATOR
Pros, 1. DOD disable 2. Delay at take off is gone 3. Adjustment of Timing, rev limiter and etc 4. adjustment of tire size, gears, and speed limiter. 5. Option to get a custom tune 6. I know there is more but I have only went for a 10 minute drive.
Cons, 1. NO Torque Management adjustments which I thought they had. 2. No heads up display 3. No alerts if there is problems 4. Have to store programmer in truck if you want to reprogram the truck somewhere else other then at home. 5. For a guy that is not good at adjusting stuff this is a more difficult unit to use.
Make sure you swing by the Diablo forums. Lots to learn there and lots of help available there. We'll help you get it fined tuned.
I have been looking around a little at the diablo forum this morning. One question I have the v8r10 do I need to update it or is it fine. Or is there more adjustments with the newer versions.
They just released a new crom (9r05). I'm gonna wait a little bit. The last one wouldn't write custome tunes to the vehicle. Since I have a custom tune, that was problem. It sounds, by all reports, it has A LOT of little bugs like that fixed. If you aren't using a custom tune, I'd use it.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
