94 Jimmy Timing
I have a 1994 jimmy and i want to set the timing where is the timing connector so i can unplug it thanks
Colin
Colin,
I have a 94 Blazer and my wire is located under the dash on the passenger side. some say it's under the carpet, but mine was hanging right below the ecm, and right next to the under-dash light. (one wire connector sticking out of the ecm harness) hope that helps.
