Air Ride Suspension For Towing
My dad just recently bought up a new 2500HD and is looking into getting an air ride system. Given that the new truck sits quite a bit higher than his '99 3/4 ton, there's much less clearance on our flat-bed and 5th wheel camper trailer. The main company he's been looking at is Talon Air Suspensions , but some of the feedback seems like it rides rougher while not towing. Although we do a fair bit of towing on the farm, we won't be doing enough to sacrifice ride quality on gravel roads and stuff around home when we are not pulling anything as its his daily driver as well. I am just curious if there is anyone that has installed or know of any good systems out there that we should take a look at.
Thanks
Firestone Ride Rite Airbags are really nice..
they have a 2 yr warranty and im pretty sure its a no-drill install.
you have some choices too if you do drill, if you mount it a little higher than what is suggested you truck will bottom out a slight bit before stopping on the bags, or if you mount it a little lower than suggested you can pick the back of the truck up a couple inches...
He looked at those earlier but isn't all that interested in a helper spring setup as compared to a full suspension swap. That's why the Talon system is more expensive.
Does he really think that he needs one of those for that truck? They bairly ever show any sign of sagging.
There is one guy on the site and filled up the back of his truck with gravel heeping and it only sagged like 2-3 inches
It's not an issue of sagging. Seeing his new truck sits several inches higher in the back end, our goose neck trailer only has a couple inches of clearance on the top of the tailgate and the side of the box. He's already put a ding in the top corner of his box from hitting it with the trailer.
Im almost 100% sure there is a metal block between the leaf springs and the axle so it sits higher. Its at least and an inch but i think its 2 inches.
if you take that out not only will it level his truck but the truck will have more clearance for the trailer.
There is a metal block there, but it looks like it's welded onto the axle, I know that this has been done quite often, but are they normally welded on like that? if you take that off will you have to fix up some sort of plate for the leaf springs to sit flush against between them and the axles?
it is NOT welded. and if it is whoever did it is an idiot.
You just undo the 4 nuts on each side take it out and put the nuts back on.
it sits in there nice and neat because there is a indent for a pin to go in the center.
I have a 2006 2500hd eclb, and i filled the box full of saud and dirt just heaping over the box rails all the way accross and it was 3700 pounds when I went accross the scale. I can say right now that it sagged way more then 2 or 3 inches. more like 5 or 6 maybe alittle more. Anyways the idea behind swtiching to complete air system is to lower the ride hieght so when you put the trailer on it fits better then increase the pressure?
Kinda like dumping the air on a semi to hook up to a trailer.
i see how that would work, but taking the block out will probably be the easiest.
Well taking a quick look at the truck tonight I didn't see any blocks like I am used to seeing on other trucks, just the fixed bracket on the bottom for the springs to sit against. I guess I'll maybe have to look closer at it tomorrow.
Yes, being able to dump the air on the system and lower the truck to hook it up would be one of the benefits to getting air ride.
Yeah thats pretty much what they would do, plus give a person a more stable ride. right capcity for the right load. Anyways I am thinking about adding a couple leafs to the back of the truck for extra load carrying capacity.
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
